LG LGCAS31865 Cell Specifications
Brand:LG
Model:LGCAS31865
Capacity:2200mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
--- mA Standard
--- mA Maximum
Discharging:2.70V Cutoff
440mA Standard
--- mA Maximum
Description:Blue Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
Its not a datasheet, but it's a start: http://www.enova18650.com/lg-lgdas31865-...R_FGutKiM8
Rated Capacity: 2200mAh
Nominal Voltage 3.7 V
Discharge Cut-off Voltage: 2.7V
Discharge Current: 0.2C-0.5C (440mA to 1100mA)
mike likes this post
Mobilis in Mobili
Cell count as of 10/10/2019
191 Cells of Everything Else
68 In progress
More info on my Google Drive
(07-05-2019, 09:52 PM)Nemo Wrote: Its not a datasheet, but it's a start: http://www.enova18650.com/lg-lgdas31865-...R_FGutKiM8
Added some of the missing info. Thanks!
