Panasonic UR18650NSX Cell Specifications
Brand:Panasonic
Model:UR18650NSX
Capacity:2500mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1750mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
2500mA Standard
25000mA Maximum
Description:Green Cell Wrapper
Light Brown Insulator Ring
18650 Form Factor
Data References:
https://www.orbtronic.com/content/panaso...650nsx.pdf
Pictures:
Proper datasheet here: https://keeppower.com.ua/download/01-201..._sheet.pdf Max charging current 5.0A (from section 10-1(1)).
