cristof
Member
- Joined
- Sep 30, 2017
- Messages
- 117
Hi All,
I need your help about MPPT input. (Sory for my english)
I have a new hybrid inverter : MPP SOLAR - MPI 5,5KW with 2 MPPT input (3000W/500V DC per input). One will be for solar panel (not install yet), and second one for my Pelton hydro generator. This generator is a permanant magnet alternator, 3 phases output (0 to 350 volt according to the RPM).
I use a bridge rectifier to convert AC to DC. this turbine is able to provide 300W DC today (Only 1 liter/second). If I connect the turbine to a 300W light bulbe, voltage is 250V DC, and Amps is 1,2A DC (250 x 1,2 = 300W). Those are true values, mesuring simultaneous with 2 multimeters. So I am sure to be able to produce 300W.
But when I connect it to my hybrid inverter the software show only around 100W in MPPT input. in this case the turbine voltage increase to 320V (as if the load was only 100W).
Many people who run small hydro as mine, used MPPT solar controler without any probleme. (morningstar, midnight...)
I do not have any capacitor after rectifier for "filtering". May be I could had a few 470uf/450V capacitor.
Does anybody know why the MPPT input does not take the full power ?
a quick drawing about how I did the test:
