My Wall of Power
I personally haven't gotten any yet, myself. I've been waiting for all you guinea pigs out there to work out the kinks and what needs to be adjusted first Tongue
They all have little pots on the back to adjust the voltage.  All after adjusting match the voltage of my multimeter.  I haven't noticed and problems with them pulling packs out of balance.  I had voltmeters on my pack before printing this new enclosure for about 5 months or so and the only time i had an issue with balance was when i accidently over discharged my pack due to several days of poor weather.
Off Grid Setup
3 - 320watt 24v Panels - MPPSolar 2424LV-MSX - 672 Cell 96p7s 5.5kw Power Wall
Retired pack 2kw 420 Cell
On Grid Setup
44 - 250 Watt Panels with Enphase micro inverters
kewls, thats nice to know about the pots; i didn't realize they had those. Makes things a bit easier, the. I might get some now Smile Thanks
Looks good. I'm running little volt meters that don't have the pots on the back and they all show different figures. It's important to have the adjustable ones.
Current: 5kW Sungrow SH5K | 1x PCM60x | 30kWh Li-Lion | 23 * 285W Mono
Upcoming: 2 x Racks 14S 18650~30kWh Each | Parallel Sungrow SH5k and More Panels
Started on powerwall 2.0.  Should have about 3 or 4 times the capacity of my first one.  Still have to put all the capacities into my spreadsheet to make sure i'm balanced and to see how many kwh i should expect.
Wattsup likes this post
Off Grid Setup
On Grid Setup
Looks great
Nice project, could you upload a spreadsheet with what you used for it and the prizes?
Cheers
Christian
New mounting design.  Sort of similar operation as Pete's.  Slide in the top clip and drops into the bottom.  Made pockets to help hold the pack and avoid chaffing  Big Grin
John.Siler, Wattsup, Korishan And 2 others like this post
Off Grid Setup
On Grid Setup
I like those clips, did you 3d print them?
                                                Choose LiFe  Wink
yup, designed and printed.
Off Grid Setup
On Grid Setup
