14s BMS on a 13s battery, can I?
Hi, I ordered this bms from china:
https://www.ebay.co.uk/itm/48V-13S-45A-E...2749.l2649
The thing is, instead of sending me a 13s bms they sent me a 14s. Can I still use the bms by just leaving the 14th connector disconnected?
I would make a 14s battery instead but I already have a charger for 13s.
Send us a pic of what you actually got.
[Image: 27711315_1943576912336612_1316176878_o.j...e=5A75D054]
[Image: 27659079_1943576942336609_126117384_n.jp...e=5A763489]
(02-01-2018, 08:27 PM)António Pereira Wrote: Hi, I ordered this bms from china:
The ebay listing does say it's a 13s bms?
                                                Choose LiFe  Wink
Yes, the listing does say it's a 13s board but I got a 14 instead.
It might work but it may be looking for higher voltages. IE it may shutdown when still not empty or keep charging over the max 54.6V I would contact the seller about this
Sorry I didn't read your post properly   Shy
                                                Choose LiFe  Wink
(02-01-2018, 09:45 PM)jdeadman Wrote: It might work but it may be looking for higher voltages.   IE it may shutdown when still not empty or keep charging over the max 54.6V   I would contact the seller about this
I have but comunication has been dreadful, and he is only replying one message per day...
Some bms's will work with different Xs configurations than max. This is accomplished by shorting out two neighboring connections. So, it's possible to short out wire #13 and #14 together and that tells the bms to keep going. I'm not sure as I don't know the documentation for that board.
Some post the shorting pattern for taking a 14s and changing to a 9s. They'd short wires #2 and #3, #4 and #5, #7 and #9, #12 and #13 to go from 14s to 9s, for example.
The bms is looking for voltage on all wires, and I suppose this kinda "tricks" the bms into thinking there are 14 there even though there's not.
Well, the seller said they asked the supplier and they said it can be used on a 13s battery they say simply to not connect the 14th wire. I'll have to give it a go once I make the battery.
