frenchclem17
New member
- Joined
- Sep 5, 2017
- Messages
- 19
Hello guys,
have read threw this thread, and here are my questions / thought :
My project is to go solar + battery (very original around here ^^), 2 strings of solar PV East and West on the roof sides, and later a third one guess where . .. south on the flat roof of my house.
I get headaches thinking how I will configure this with the MPP inverters, I have studied the Victron solution, but it's too expensive for me.
Regarding power usage, I'll start easy, and increase capacity with time, and confidence in my skills. So let's say 1-1.5kWp on each side of the roof and 2-3 kWh battery to start with. In the end, I think 15kWh is what I need to run the house ...
Based on my solar potential, I would need 15kWp to have enough solar power during winter ! I'll propably never get so much, but I keep that in mind.
It will have to be grid tied just for times with battery + solar shortage, but with the ability to not feed anything to grid, my house is running on a single phase.
What should I do :
a- go with a big inverter single phase with 3 mppt charging my battery bank : 5048MST 180A 5kW : not Ideal to start with because it's not cheap, its made for 48V battery, also harder to increase capacity
b- go with three smaller inverter PIP MSX 2424 in parallele: not ideal either because it's for 24V battery only, has limited PV Power input of 1500W (so guessing Max 2kWp string), but I could built up my system as I progress, starting with a string, an inverter, and the battery, then add the second set, ...
c- go with multiple inverter 48v battery capable in parallele like the PIP 3248 or the pip 4848 MS ...
d- anyother option I havn't thought of
Last but not least, I also read a lot about BMS, and the Batrium system seems to be the best so far (not talking about price) : How do batrium and MPP Inverter talk together ? if they don't is it because they really don't need to share information, and if not, isn't it the down side of the couple MPP / Batrium?
What should I do :
