daromer said:It depends on the type of BMS you are using. If its a dumb BMS its not that big of an issue BUT it can be that you in the end get packs with uneven voltage. If thats not a problem if they are 10mV appart then go ahead. If its just 1 cm then no iissue but if we talk about 50cm then keep them same, fuse em and make sure they are thick enough!
daromer said:As long as the longer ones are thicker then you dont need to extend em all. Just fuse them if you plan on doing it and you will be ok.
