Sony SF US18650V Cell Specifications
Brand:Sony
Model:SF US18650V
Capacity:--- mAh Rated
Voltage:--- V Nominal
Charging:--- V Maximum
--- mA Standard
--- mA Maximum
Discharging:--- V Cutoff
--- mA Standard
--- mA Maximum
Description:Green Cell Wrapper
Black Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
While I don't have a Data Sheet these have been pulled from Makita 1.5A and 3.0A tool packsĀ
indicating the have a capacity some where around 1500mah
(04-17-2018, 06:03 AM)Broncosis Wrote: While I don't have a Data Sheet these have been pulled from Makita 1.5A and 3.0A tool packsĀ
Yes, I concur, 1500mA from drill packs. Makita also use Samsung 15R/25R as well, which are rated 23A to 30A discharge max. I suspect that these are the same. Suitable for eBike etc.
I also got a bunch from makita powertool batteries. However, what seems strange to me is that there aren't connections on every group; there is only one on p2+. Never seen something like this actually. However, I would expect this to work quite well if the cells were self-balancing, which I don't think they are.
