Swazytrain
New member
- Joined
- Mar 4, 2017
- Messages
- 4
I am currently working on a project that needs a Li-Ion battery to power a 50Lb. thrust min kota riptide trolling motor. I am a novice at this so you might have to bear with me here a bit. The end result i am looking for is to have a 12V Li-Ion battery with a 80-90Ah rating. i would like to make it up out of two packs to be mounted seperatly in a long staggered formation....
something like that.......
The cells i will be using are CGR18650E cells out of old/new panasonic tough book batters. they have a nominal voltage of 3.7V and a standard capacity of 2550mAh. what i need to find out is if it ispossible to do this in this configuration..... how many cells do i need....how do i go about the wiring configuration and what is the correct BMS for this application.... Do i sound like im asking the right questions?
