Crimp Daddy
- Feb 21, 2018
- 973
I have some EV car batteriesthat come in modules that are 5 in series, 1 in parallel.
I decided to use them 3 modules in series to give me 15s configuration, but the complexity is getting it wired up efficiently to use a BMS across the bank, vs a separate BMS per each individual 15s string.
I am going to spend money on something like a Batrium I dont think it would be cost effective to try and monitor each parallel string separately, even though it would give me the most data as each series string is electrically disconnected from the next pack.
That said, it appears it would not be too difficult to wire each series cell to one another across the parallel banks.
My concerns are more to do with:
-Balance lead wire size between cells
-connecting balance cable cell to cell using a y cable vs each cell going directly to a bus bar.
-wire lengths (should I keep them all the same
-fusing off each cell tab at the battery for balance leads
I wanted to share some ideas and get the community opinion on how best to attack this configuration as I cannot easily (physically) group all the parallel cells together in one large pack due to them being in module format.
Considering its just a balance cable, perhaps 14 AWG to 12 AWG size wire would be more than sufficient
Here are the connections at each balance lead location, very easy to tie in!
[size=small]A better view of the module connections.[/size]
[size=small][/size]
Sketch 1 Wire each balance head from Cell 1 to Cell 1 using Y-cable at the battery (not sure if this should be fused at the point of connection) A break in the connection on one cell would leave it stranded from the rest of the pack.
Sketch 2 All series cells are wired to a bus bar and then from the bus bar to the BMS.
Option 3 Do not wire any series cells in parallel and opt for discrete BMS or monitoring per parallel battery pack.
[size=small][/size]
