Sanyo UR18650FB Cell Specifications
Brand:Sanyo
Model:UR18650FB
Capacity:2400mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
2400mA Standard
--- mA Maximum
Discharging:--- V Cutoff
--- mA Standard
4800mA Maximum
Description:Red Cell Wrapper
Green Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
I've found 9 Sanyo's with green rings in a Dell 11.1V 7200Ah battery (Type Y4367). These are different to all my other Sanyos as there is no embosed "sanyo" or model number, just the date stamp.
I'm not 100% sure they are UR18650FB, but if I run the numbers back from the Dell pack, they should be 2400mAh cells and with the green ring, they probably are UR18650FB
(10-18-2018, 09:24 AM)heyhey Wrote: I've found 9 Sanyo's with green rings in a Dell 11.1V 7200Ah battery (Type Y4367). These are different to all my other Sanyos as there is no embosed "sanyo" or model number, just the date stamp.
I have never seen a Sanyo cell in any Dell battery. However that battery is from 2005. Much older than the Dell packs I have.
How do those cells test? Or are they heaters?
They tested pretty well. Average capacity was 2200mAh. Pretty impressed with that actually. No unusal (usual for Sanyo) heat.
