E-Go Kart 18650 Pack - Cell fuses or nickel strips?
#41
(05-04-2018, 07:23 PM)garolittle Wrote: Thanks for your question. Based on the drawing above, it would be three separate 24v packs (7S20P) connected in series which would result in 72V. Assuming 2.5 amp hours per cell, this would result in a total “Watt Hour” calculation as follows: Total # of cells: 420 mutlpied by 3.7 nominal voltage per cell and then multiplied by 2.5 amp hours per cell.  This would be approximately 3,800 Watt hours for the entire 72v pack.
The calcualtion is as follows: 7s 20 P will with 2.5 amp cells give you: 2,5 x 20 = 50 amps x 24 volts = 1.200 watts.
50 amps x 72 volt = 3.600 watts. Putting pack in series ups the voltage not the amperage.
garolittle likes this post
#42
Thanks Sir. I appreciate your response
#43
Ok.  I know I have been all over the map with my ideas regarding the battery pack but I have settled on one of the following two ideas:
1) A 20S10P pack (72V) on each side the passenger seat (connected in parallel for a total of 72V)
2) Two 10S10P packs (36V) connected in series on each side of the passenger seat (resulting in 72V).  These connected packs on each side of the drivers seat would in turn be connected together in parallel (which would provide 72V).
The math would be fairly simple (400 cells in either case).  Option 1 would involve a larger pack on each side (each with a BMS).  Option 2 would be more "modular" since there would be a total of four modules (and four separate BMS's).
The picture below shows the space on each side of the seat where the battery packs would be installed (on some type of tray).  So..... based on this configuration, we are back to the basic question.  "To fuse individual cells with spot welding or not to fuse".  That is the question. Soldering the fuses to the cells is not an option. This is really just a question of using pure nickel strips to make all connections or using copper bus bars with small copper wires spot welded to the cells as individual fuses.
Max amps will be 300 amps and constant amps will likely be in the 50 - 60 range.  Thanks for any ideas.
Attached Files Thumbnail(s)
#44
what motor are you going to use?
#45
Motor: 72V Motenergy Brushless Motor (ME0201014201). Continuous current - approximately 50 - 60 amps at 72V
Charge Controller: Sabvoton (svmc72150) DC Current Limit: 100A
#46
Two changes. 1) I will probably use a different charge controller but the max amps will probably be no greater than 200 amps. 2) battery pack will likely be 8P (instead of 10P) due to size constraints. At 200 max amps from the charge controller, this would be 12.5 amps per cell. The Samsung cells can output 20 amps continuous so I should be ok. Any thoughts?
#47
any progress on this build?
in process.... 7s120p just very slow.
#48
Slight change of plans. For safety reasons, we are going with 48 volts and Nissan Leaf batteries instead of the “Tesla-style” 18650 batteries.
https://www.facebook.com/247184812650883...857410878/
Here are the specs. Go kart to be finished by March 31, 2019.
BATTERIES: 7 Nissan Leaf battery modules (7.8V each) connected in series for 54V nominal (approximately 58 amp hours). The picture of the go kart frame shows the proposed placement of the battery modules (4 on one side and 3 on the other side).
BATTERY MANAGEMENT SYSTEM (BMS): Orion Jr. BMS with pre-wired CANBUS harness, voltage tap harness, shunt resistor (500A) and basic analog display
MOTOR: Motenergy ME0708 Permanent Magnet Direct Current (DC) Motor, 48V, 8 hp cont, 15 hp pk (300 amps max/150 amps continuous)
CONTROLLER: Alltrax SR-48300 48V/300A. The charge controller would go in front of the driver (under the steering wheel).
WIRING: 4 AWG gauge wire to/from charge controller, motor, and battery pack
THROTTLE: EZ-GO Pot Box
CONTACTOR:
Gigavac GV200QA-1 48V 500 Amp
Stay tuned for more updates.
The VenomKarts Team
VenomKarts, LLC
100 User(s) read this thread:
hbpowerwall (09-04-2018, 02:06 AM), daromer (02-01-2019, 03:36 PM), mike (02-01-2019, 09:37 PM), 18650Shrink (04-03-2018, 02:26 AM), Joaquinsfy (02-26-2019, 01:43 PM), owitte (05-09-2018, 06:30 PM), Majorphill (05-05-2018, 12:53 AM), spj007 (04-15-2018, 02:42 AM), Korishan (08-30-2019, 03:34 AM), A + A (04-21-2018, 07:28 PM), PAF (02-01-2019, 03:34 PM), Batrium (05-05-2018, 10:37 AM), ozz93666 (05-08-2018, 04:23 AM), lehll (08-28-2018, 10:20 PM), Mike C (04-04-2018, 12:34 AM), jdeadman (05-09-2018, 03:05 AM), wim (05-08-2018, 08:55 PM), The-J-Man (01-01-2019, 08:30 PM), rebelrider.mike (05-06-2018, 05:08 AM), watts-on (02-01-2019, 04:04 PM), Dan Lim (08-31-2018, 10:31 AM), Joost2 (04-28-2018, 09:46 PM), Stefaan De Ridder (02-01-2019, 01:52 PM), BlueSwordM (06-29-2018, 03:09 PM), Dennis Van Hoek (09-12-2018, 09:48 AM), Mazlem (07-26-2018, 04:16 PM), Geek (02-04-2019, 04:30 AM), Bigfillly (08-26-2018, 10:13 AM), Ivo Staelens (08-05-2019, 01:28 PM), mr_hypno (04-21-2018, 01:23 PM), floydR (04-21-2018, 03:06 AM), mickduc (04-21-2018, 08:22 PM), hookemdevils22 (06-29-2018, 05:32 PM), DarkRaven (02-02-2019, 01:33 AM), zag2me (04-20-2018, 12:48 PM), emerca (05-20-2018, 04:04 AM), garolittle (02-05-2019, 04:20 AM), zeelog (06-10-2019, 02:37 AM), Solexx X (05-05-2018, 08:38 AM), Charly144 (05-09-2018, 06:17 AM), Lerronious (08-03-2018, 01:27 AM), Detritalgeo (04-28-2018, 06:18 PM), BaronVonChickenPants (04-04-2018, 01:30 AM), spinningmagnets (04-10-2018, 05:51 PM), Stijn Wever (08-11-2018, 09:55 PM), Jason Morris (05-05-2018, 03:01 AM), brwainer (05-09-2018, 03:53 AM), Ian@eagland.co.uk (06-24-2018, 08:26 PM), HughF (09-04-2019, 05:24 AM), Micka76550 (08-30-2018, 10:03 PM), Oran Maliphant (04-25-2018, 04:35 PM), benwilliam (04-04-2018, 09:43 AM), Jason (05-08-2018, 03:13 PM), goeielewe (05-19-2018, 10:27 PM), EGOksy (05-19-2018, 06:00 PM), gpn (04-03-2018, 04:26 PM), Salettes90 (04-10-2018, 06:20 AM), Chablis_m (04-14-2018, 02:10 PM), Headrc (02-01-2019, 03:32 AM), Tvixen (03-04-2019, 12:08 AM), David (08-23-2018, 02:48 PM), rodagaster (05-08-2018, 11:55 PM), thanar (05-12-2018, 07:42 PM), Dala (04-03-2018, 10:19 AM), DK100 (05-15-2018, 09:32 AM), Crimp Daddy (04-11-2018, 04:16 PM), Redpacket (04-16-2018, 10:46 AM), completelycharged (05-04-2018, 04:58 PM), Bigdinner (04-09-2018, 05:38 PM), Zvonko000 (04-15-2018, 02:28 PM), Jonas Vanbeveren (07-31-2018, 05:33 PM), iomagico (04-14-2018, 09:17 PM), Gyroman (05-23-2018, 02:46 PM), Jmp (05-25-2018, 05:53 AM), solar_18650 (05-08-2018, 08:27 PM), sniperdude24 (04-16-2018, 11:54 AM), colibri1 (04-16-2018, 10:17 PM), j9yhc (04-19-2018, 03:46 AM), Joel (05-28-2018, 06:05 AM), farmerjohn (04-28-2018, 10:47 PM), Astrid (04-21-2018, 11:28 AM), ANegron (06-05-2018, 09:54 PM), pearlite (04-25-2018, 07:34 AM), Monsterbeats19 (06-05-2018, 02:06 PM), Donttellthom (05-03-2018, 03:24 AM), Battlewind (05-05-2018, 07:11 PM), Fit (05-08-2018, 04:28 PM), philsocal (08-28-2018, 04:19 PM), Leo_C (05-11-2018, 01:11 PM), JDish (05-18-2018, 12:07 AM), CBlack (05-14-2018, 03:34 PM), roswitha mamutschka (05-16-2018, 07:49 PM), BrianMonks (05-16-2018, 05:38 AM), jakonthestak (06-16-2018, 04:19 PM), Sholphin02 (05-25-2018, 02:15 AM), Riplash (02-02-2019, 02:24 PM), puuhapet (06-06-2018, 10:48 AM), cristi (06-06-2018, 02:00 PM), Katarn_89 (07-22-2018, 07:02 PM), djotter (04-28-2019, 08:36 AM)
