SolarEdge (SE7600A-US) Inverter and custom battery pack?
(05-22-2019, 10:24 PM)Charly Wrote: If anyone is interested: I'm an electrical engineering student who has a SolarEdge inverter and I think I've found a straightforward non-hacky solution which integrates perfectly into the SolarEdge inverter as if it was just an LG battery. Let me know if you are interested. It's taken me about a week of research and trying to figure out the LG Chem's CAN Bus SunSpec protocol.
Yes, I love that info. What do you think about this? I am a Restoration contractor and love my work truck, dual cab, long bed, petrol! That's what i hate. I want battery storage that I can drive daily and charge it on the job sites power pole while at work, come home and plug and play at night. Swap out the motor and transmission with 125KW battery bank and 12000 watt inverter for tools instead of plugging into the power pole. I mean, it's a mobile power plant!
Hello All,
not directly an answer to the SolarEdge to diy battery bank question,
but more mainstream: solving the issue of can reverse engineering various inverters/hybrids to work with diy-battery banks
So perhaps we could share our findings
A small team ( Tom/UK, Eeven/No, Daniel+Carel/NL) is currently trying to figure out the new SMA HV StorageBoy series 3-6.0 AC coupled inverters can protocol hooked up to a BYD 6.4 battery bank,
(see photo of test rig SBS6.0 + Byd box)
Goal is get to the can protocol, from the BYD battery, we want to use SIMPbms to be the interface between EV battery, and SMA SBS6.0,
and hopefully more brands of inverters
For the EU based members:  SolarEdge/ Kostal Plenticore PLUS/ Solax X3-hybrid10-T3ph, are very interesting targets
Please contact me if we could share and help each other.     c.hassink@pro-lox.nl
SIMPbms links: https://github.com/tomdebree/SimpBMS/blo...20V0.9.pdf
best regards
Carel
pro-LOX, Carel Hassink,
Obdam, Netherlands
I am very interested. I have 2 StorEdge systems inastalled in my house for testing. I would love to work with you. My email is emmalucian att Gmail dot com. (Hope you can figure that out. Lol)
Question
Anything new on using a StorEdge inverter with a DIY pack?  Is there an appropriate affordable BMS which will talk to the StorEdge?
rearden
Iam interested in this also I have a SolarEdge 7600 Also. And i want my 18650 power-wall to work. Has anyone successfully made this happen yet thanks. If so Please elaborate.
Anybody have any luck with this? I’m thinking about doing doing this with my SE10000H. Seems a bit more difficult/risky due to being batteries being HV.
Anybody hear anything back about this? I’m pretty interested in building a battery for my SE inverter. I’ve seen BMS which seem like they should be able to communicate with the inverter. Only problem is the voltage. Would need a DC to DC converter to take the batteries from 48v to ~400v and allow current to go in either direction
Hello, last year, SolarEdge introduced a new inverter with 48v (S-SE10K / RWS-SE8K / RWS-SE7K / RWS-S) battery management built in. Now the DIY battery pack 48V can be used with this inverter but we need to understand if there is any chance to comunicate with the inverter or not.
There is any body who did this?
Thank you
Dan
