hbpowerwall
Administrator
- Oct 7, 2016
- 2,218
BatteryHasher has a second home in the workshop where I can keep a better eye on it
Tech4U said:I have a rig to mine with but have no clue as to where to start. Any help would be great.......
Korishan said:If you build your own power supply, you could go with a buck to drop voltage down to 12V, then use regulators to get the 5/3.3 to the motherboard. Then use bucks for the gpus. Depending on amp draw, you could use 1 per card, or 1 for several cards, depending on which buck you got.
That's just a guess at this point, though. Not sure if that'd work directly, but could be expounded upon
