Nissan Leaf powerwall
I just connected up my leaf batteries for the first time and started a charge cycle on them
Gotta say - so far they are awesome!
I am running 42 modules total in 14s6p configuration
Charging at around 110 amps.  I let it go for an hour and they don't even warm up!
Now to configure Batrium!
Just thought I would share!
jdeadman, lnxpro, DK100 And 1 others like this post
A Nissan Leaf by itself 48s1p modules can charge at 120A with just a little heating, so at 6p I imagine those cells will last a long time Smile what voltage per cell are you charging to/from? For long life they should be cycled from 4.0-3.5V or so.
(05-07-2018, 07:04 PM)rev0 Wrote: A Nissan Leaf by itself 48s1p modules can charge at 120A with just a little heating, so at 6p I imagine those cells will last a long time Smile what voltage per cell are you charging to/from? For long life they should be cycled from 4.0-3.5V or so.
So far these batteries are amazing!  I had them charging at 180 amps the other day as a test by combining my solar and my grid charger.  Their temp did not rise at all after 2 hours
I am keeping them between 4.1 and 3.5 but most days I only go down to 3.65 before the sun comes up again
My system is grid tied but with these batteries I am now 100% off grid with a 6kw array which is 50% east and 50% west facing
Today I generated 33Kwh which fulfilled all my loads and left me with 100% charge at the end of the day.
My old lead acid battery would only last me a few hours overnight - they were terrible.  I should of gone lithium from day 1
I'm looking to fill my rack with 3-4 more car's worth
hbpowerwall, DK100, jdeadman And 2 others like this post
I shopping for a local wrecking yard that has a car or two, I found these to be a good cost per kWh and ironically I have a Dell server rack like that too, our builds may be brothers.  I'd like to follow your progress and any details about prices and harvesting and testing them.  Thanks and good luck!
I know this is an old thread, but maybe you are still watching it....
What are those black metal plates that you are using to keep the packs compressed? Did you find something premade or did you cut it yourself?
thanks.
(01-25-2019, 01:28 AM)lnxpro Wrote: I know this is an old thread, but maybe you are still watching it....
thanks.
Those are just some metal plates that I ordered from a local metal shop pre-cut to the size I needed
I then drilled holes in them to match the holes on the batteries.  Then just spray painted them with some cheap rust paint
They do a very good job.  The batteries need to be held in slight compression
Oh. ok. Do you happen to know what type of metal did you request? assuming aluminum plates are too flexible.
i am trying to do something similar and want to put light compression on the modules. I was thinking plywood but that adds a lot of thickness to each pack.
(01-25-2019, 01:41 AM)lnxpro Wrote: Oh. ok. Do you happen to know what type of metal did you request? assuming aluminum plates are too flexible.
I used some hot rolled steel sheet
Here is the exact specs from my invoice:
0.188 ST CQ SHEET STEEL-HOT ROLLED SHEET A1011 CQ 11.81 Inches X 7.87 Inches
I bought it here:
https://ecommerce.metalsupermarkets.com/...T/A1011_CQ
I used metal so that there was nothing in there that is combustable (aside from the batteries!)
Good luck with your build!
lnxpro likes this post
Farmerjohn:
Any idea how many miles where on your batteries when purchased or given a second chance? And did you happen to capacity check them? I'm currently going through mine 1 at a time. I suppose to simply ensure they function and cycle correctly being re-purposed and all. Mine apparently had 63000 miles when harvested (didn't know this at time of purchase). I seem to be getting between 307 and 318 WH per Module, from 4.15v to 3.25v. Only 4 of 48 tested so far. Needless to say i am slightly disappointed at the results, however as long as they are relatively consistent i will proceed and use.
I suppose i jumped into this and now that i have started the lengthy time grueling process and reading so much on Leaf battery Degradation i'm getting concerned. Any input or advise would be greatly appreciated. Building will not start for awhile still in planning stages, hence the reason for advise.
Thank you: I hope to have success as you have shown.
My story began with the Nissan Leaf. Now i want batteries for everything. SOMEBODY STOP ME !!!!
My batteries had approx the same milage on them
I have since bought 3 more car's worth of batteries.
I bought them from someone who specializes in recycling EV batteries. He provided me 4 matching sets that each tested out to ~58AH. He had a large supply and was able to pick out sets that matched up pretty evenly. He sold them to me pre-tested and guaranteed
They have been performing extremely well - I am very happy with them. So far I have not seen any appreciable sign of degradation. Compared to their life in the car - they are hardly breaking a sweat.
They do not even heat up when charging / discharging. I have not been getting much solar this winter so I have been buying power from the grid at night when the price is cheaper, then using it the rest of the day from the batteries. I use about 15 Kwh/d and they charge at about 140 amps for a couple hours or so
I keep my cell voltages between 3.5 and 4.1
Let me know if you have further questions! Good luck!
