LG LGDAHA11865 Cell Specifications
Brand:LG
Model:LGDAHA11865 (ICR18650HA1)
Capacity:1300mAh Rated
Voltage:3.68V Nominal
Charging:4.20V Maximum
650mA Standard
4000mA Maximum
Discharging:2.50V Cutoff
260mA Standard
15000mA Maximum
Description:Green (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
https://akkuplus.de/mediafiles/Datenblat...A11865.pdf
Pictures:
I found these LG LGDAHA31865 in Makita power tools packs, rated for 1.3 Ah.
