Home PowerDrive V2 - Germany ** 33+ kWh ** Big Power ++
Wink
Hello everybody
My new project - Home PowerDrive V2 - Germany
EASUN POWER 5000W Solar Inverter 80A MPPT Off Grid Inverter 48V 220V Hybrid Inverter Pure Sine Wave Inverter 60A Battery Charger
(not mounted yet)
+ Solar Power 6095Wp (23x265Wp - Astronergy PENTA 5BB 265Wp poly - ASM6610P Serie  - Made in Germany)  (not mounted yet)
+ LI 18650 Second Life Storage (not mounted yet)
to test batteries
6x Opus BT-C3100 v2.2
3x imax B6
20x TP4056 mini Charger + (40x TP4056 mini Charger not mounted yet)
New:
Fuses to test with the 18650 via Aliexpress now arrived: 2000x 0,5A, 2000x 1,0A , 2000x 2,0A  Axial Fast Glass Fuse With Lead Wire 3*10
https://de.aliexpress.com/item/1000pcs-L...50661.html
To repair defective cases on the 18650 2x 10 Meter via Aliexpress now arrived : CNIM Hot 10M 29.5mm PVC Heat Shrink Tubing Wrap for 1 x 18650 Battery Light Green
https://de.aliexpress.com/item/CNIM-Hot-...Title=true
The first 100 pieces 4x5 Cell 18650 Batteries Spacer Holders via Aliexpress now arrived : https://de.aliexpress.com/item/Neue-20-3...06477.html
*** I hope it is ok to set the link here. Otherwise please short info and I'll take him out. ***
Follow pictures
PS: I would be glad about German contacts to Kollgen in Germany
hbpowerwall, DK100, WuggyBuggy like this post
I'm testing
Bin am Testen
Confused
hbpowerwall likes this post
Welcome and keep on building!
Herzlich willkommen und viel Spaß beim Basteln Smile . Und bei Fragen einfach fragen Big Grin
Have sun!
Oliver
Cells tested: 6.234 (overall: 12.414 Ah, average: 1.991 mAh)
Cells in production: 3.360 (overall: 7.056 Ah, average: 2.100 mAh)
Powerwall setup: 7s480p, 1.008 Ah, 26 kWh
Project page
Live solar/powerwall values
Daily graph
My Inverter
ISolar SM 5kw 48vdc = EASUN POWER 5000W Solar Inverter 80A MPPT Off Grid Inverter 48V 220V Hybrid Inverter Pure Sine Wave Inverter 60A Battery Charger
https://de.aliexpress.com/item/ISolar-SM...4c4daz7GIe
Today 10 new E-Bike Akkus = 400 LiPO 18650
all Lipo 2900 to 3400
Now I have something to do again on the weekend.
Get 68 kg of used batteries today.
I guess about 1000-1200 cells 18650 times when it runs well.
Wishing you a nice weekend
Jetzt habe ich wieder was zu tun am wochenende.
68 kg gebrauchte Akkus heute neu bekommen.
Ich Schäze mal ca. 1000-1200 Zellen 18650 wenn es gut läuft.
Ich wünsche ein schönes wochenende
jdeadman and raccooon like this post
I think its lithium mangane what you’ve got and no lipo...
Hey Walde,
I've also started with my Powerwall this year.
I see you got some e-bike batteries.
I also got some - Brand Fisher - like the left on on your picture.
Question: how do you get the cells out of the cage, as mine are not easy to dissassemble.
Additionlay, mine are flooded with some black rubberliquid, big mess to get rid of.
ATM I have to use mechanical force to get the cells out, but they loose their insulation with this methode.
regards
cadric
Hi Walde
ich hab in diesem Jahr auch mit dem Bau einer Powerwall begonnen.
Ich hab auch einige e-bike Akkus, gleiche wie der Linke auf deinem Foto, Marke Fischer.
Frage: wie bekommst du die Zellen aus ihrem Käfig, ohne sie zu zerstören? Meine lassen sich nicht zerlegen.
Zusätzlich sind meine auch noch mit einer schwarzen, gummiartigen Flüssigkeit eingegossen, ziemiche Sauerei, die zu entfernen.
Zur Zeit entferne ich die Halter Pol für Pol mit einen Holzmeißel, um dann die Zellen, die Parallel geschaltet sind separat herauszutreiben.
Dabei verlieren sie natürlich ihre Isolierung.
Gruß
cadric
2. Offgrid System 09.2019 7,5 kWp: 25 x 300Wp Solarworld (5x( 3S + 2S )), 2x PIP-5048MS, Batrium WM4, 1st Battery Bank: 840 cells in 14S60P with 80Ah cap.
(06-22-2018, 11:10 AM)cadric Wrote: Hey Walde,
regards
cadric
Hi Walde
Gruß
cadric
Plastik Werkzeug und eine Kombizange und einen Seitenschneider + Lederhandschuhe / Schweißerhandschuhe
Plastic tool and a combination pliers and a side cutter + leather gloves / welder gloves
MfG Dirk
