A growing powerwall in Germany
Hello,
For about a year I collect used 18650 cells to build a powerwall for our house.
We have a 6kW photovoltaic system and a lot of electricity, for which we only get 12 cents per kWh. When the sun is gone, we buy expensive electricity for 25 cents / kWh.
Now I had enough cells together and our battery is at the start, together with a 3000W inverter, he supplies almost our entire house with electricity, as long as the solar system supplies none.
I started with two rows.
Now I have four rows together and Batrium running.
There is room on the wall for a total of 16 rows, one row has about 1.1 kilowatt hours
I took the concept from Oliver and his ThreadI thank him for that!
Greetings from Jens
Geek, Redpacket, jdeadman And 4 others like this post
Neat... very neat...
Why do you German guys hide those pretty walls in the celler  ??? This belongs in the livingroom right next to the TV  Wink
jdeadman, Stramon, completelycharged like this post
Great install bud!
Stramon likes this post
(06-20-2018, 06:27 PM)wim Wrote: Neat... very neat...
I also wanted to build the powerwall next to the fireplace in the living room but my wife was against it.
I also think in case of fire, the basement is the better place. Everything around it is made of stone or concrete.
congrats, love your design Big Grin Big Grin . Looks very nice and clean, hopefully the wall is not wet, look like you screwed your busbars directly into it.... I remember I had a problem with humidity on my connection board where all battery banks come together. The screws where rotten after 4 months while the wall was almost completely dried out because of the current Smile . After theat, I screwed the vusbars to a thick piece of wood. Fortunately, I'm using plastic holders for the busbars of my powerwall.
Cells tested: 6.721 (overall cap.: 13.587 Ah, average cap.: 2.021 mAh)
Project page
Live solar/powerwall values
Daily graph
(06-21-2018, 06:53 PM)owitte Wrote: congrats, love your design Big Grin Big Grin . Looks very nice and clean, hopefully the wall is not wet, look like you screwed your busbars directly into it.... I remember I had a problem with humidity on my connection board where all battery banks come together. The screws where rotten after 4 months while the wall was almost completely dried out because of the current Smile . After theat, I screwed the vusbars to a thick piece of wood. Fortunately, I'm using plastic holders for the busbars of my powerwall.
Hello Oliver,
for the parall busbars I took cable pipe holders from the hardware store.
I think you have the same. Rolleyes
All other cables and connection points are also separated from the wall.
But good to know how to drain a wall with a powerwall. Big Grin
owitte likes this post
Hello Oliver,
ok, next time I'll have a closer look before posting unnecessary advice Wink
Project page
Daily graph
Very nice construction Jens.
Do you have a link to that inverter?
thanks
Frank
(06-28-2018, 05:01 PM)Franky Beuselinck Wrote: Very nice construction Jens.
thanks
Frank
Hello Frank,
thank you!
This is the Inverter.
Greetings Jens
A quick update. My battery is growing slowly. With ten rows (140P each) I'm now at around 10 Kwh.
In the last few years I have built two rows each.
With the help of the battery, our house runs almost 100% on solar power from March to October, only the stove needs three-phase current.
Greetings Jens
pflicht, ajw22, atego And 2 others like this post
