Beginners Guide to Processing 18650 Cells | Cell Database
AKE Powerwall
Hello!
Setting up this thread to give you all an easy way to follow my power wall build.
This is all one school project.
My power wall will feature modules like : solar mppt battery charger, BMS, Inverter, and touch display.
All these systems will be built in one unit and controlled by an Arduino.
Hope to see you and others following this project.
All cells have their origin from laptop batteries.
First stage: Taking out cells and getting them ready for charging. This step involved measuring each and every cell by their voltage. All cells with voltages greater than 1V have been accepted.
Second stage: Charging the cells UP TO 4.2 Volts and storing them for at least 10 days.
Third stage: Measuring voltages on each and every cell again before discharging. All cell with voltage drop greater than  0.1 volts were  not accepted.
Fourth stage: Discharging the cells. 1900 mah minimum.
Fifth stage: charging discharged cells back up to storage voltage 3.8 Volts.
All cells is fused with fuse wire (positive side) . Tests have been done on this particular wire. Criteria like max Amp draw by length of wire have been tested and checked. Updates will follow on this subject.
From a total of 149 laptop batteries i got 895 cells. 560 (62.6%) of these is usable in form of a power wall. All the other cells were ether dead, had to high inner resistance or to low capacity.
The process so far..
Say goodbye to Voltage regulators. Too much Heat!
New and final layout for my Arduino BMS/ Charge controller
Moving my Powerwall for final assembly and testing
PCB Done!
Working late nights with my most important tool.. Coffe Big Grin
Nearly there.. PCB for BMS almost finished.
2 NEW and essential deliveries.. Inverter and..
Custum made "fuse box" for my powerwall components. This will give you an idea were i'm going with this project..
Testing out possible layaut for batteries and inverter. Solar mppt, bms and Arduino will fit down in the bottom right..
Ventilation and other essentials will be fitted later
A lot of work is also delegated hardware components (BMS, Charge Controller, etc)
Arduino progress.. BMS code and mppt charger code  70% finished.
These codes will eventually be implemented true this TFT 3.2" lcd Shield + Touch Screen
Early stage in TFT screen program and Yes, this layout is written in Norwegian. Code will be open source  in an English version as well (when finished).
Huge updates right around the corner..
Arduino updates will follow shortly.. [Image: biggrin.png]
First pack done   Big Grin                                                        7 packs done  Big Grin Big Grin
Soldering my first pack..
10 mm2 wire (7 AWG). Final busswire idea.                   Testing out layouts for the packs..
As you see the wires are fastened by sip ties
at four points. Sip ties glued to battery
holders. These buss wires were changed to
one wire running back and forward..
See images further down..
Soldering negative side.
Getting there..
Early stage.. Packs 3/4 done.                                         All cells getting one of these.
Missing some cells for a 80 cell config.
Fist patch of batteries ready to be dismantled                 Loots of colors
Ready for charging
My charging/ discharging station
grgdgreek, mormor1971, Rad And 5 others like this post
Looks great.
Follow my journey as a Fire Fighter builds his own DIY Powerwall.
https://www.youtube.com/channel/UCOV6v9i...IZ_49k-WpA
Thanks Big Grin
Current: 2.5kW Inverter (Off grid)  | Custom mppt solar charger | 160Ah@24V 18650 | 200W Solar PV
Nice wire!
can't wait to see this up and running looking good so far
Arrow Opus Dischargers - Definitely my choice pick for dischargershttp://amzn.to/2CmSpmj
What are the red circles? This is looking fantastic!
The red circles are protectors for the positive end.
Andreas Kvernes and hbpowerwall like this post
For just that little extra protection.. a good idea for sure
(03-28-2017, 02:48 AM)hbpowerwall Wrote: For just that little extra protection.. a good idea for sure
Exactly. Never really liked the idea of hot solder at the positive terminal. This made me a bit more comfortable Tongue
Where did you buy the red circles?
100 User(s) read this thread:
hbpowerwall (05-25-2017, 05:51 AM), AZ_Tekkie (05-05-2017, 05:04 AM), Chickey (06-21-2017, 05:41 PM), Brian Lawrence (05-11-2017, 08:33 PM), pacm31 (04-30-2017, 01:01 AM), Minx (03-28-2017, 02:11 AM), daromer (06-21-2017, 05:48 PM), FiremanDIYPowerwall (04-30-2017, 08:59 PM), mike (05-31-2017, 02:49 PM), Toochi84 (04-30-2017, 01:23 AM), goodnowm (10-25-2017, 01:42 PM), Swolrath (06-21-2017, 11:31 PM), AveRageJoe (04-26-2017, 05:09 AM), BigBen (06-22-2017, 04:29 AM), station240 (05-04-2017, 09:14 AM), Joaquinsfy (05-18-2017, 01:32 PM), NiVa (06-01-2017, 12:01 AM), Lux_Gamer (05-26-2017, 07:58 AM), Andreas Kvernes (10-01-2017, 01:24 PM), owitte (05-29-2017, 09:18 PM), opus40 (05-06-2017, 05:54 AM), ken (03-22-2017, 06:32 AM), dakoal (05-02-2017, 07:49 AM), VdVoort4 (06-07-2017, 12:27 PM), Glubux (05-17-2017, 08:07 PM), Grazor (05-04-2017, 01:04 PM), Majorphill (04-29-2017, 01:33 PM), Elwood (03-31-2017, 12:50 AM), riveracc1 (08-19-2017, 06:25 AM), coolfx (06-22-2017, 06:21 AM), Herebus (05-21-2017, 12:15 AM), timholmesjr (05-10-2017, 12:12 AM), Rerouter (04-28-2017, 11:18 PM), DanielD (03-31-2017, 12:52 AM), ruby2 (10-01-2017, 10:30 AM), JustJim (12-26-2017, 02:36 AM), Korishan (10-01-2017, 05:32 PM), A + A (10-01-2017, 03:25 PM), P.Tasyo Powerwall (03-28-2017, 01:37 PM), PAF (10-01-2017, 05:21 PM), FERCSA (04-29-2017, 12:09 PM), Prahe86 (04-29-2017, 05:06 PM), APD (03-28-2017, 04:57 AM), pfromero (03-28-2017, 03:33 AM), Bob Muster (03-27-2017, 10:16 PM), Jose Reyes (05-04-2017, 01:46 AM), Batrium (06-06-2017, 09:23 AM), Darmok (06-30-2017, 02:48 PM), Wattsup (05-16-2017, 11:43 PM), Project (04-29-2017, 02:25 AM), Batteriapan (05-24-2017, 11:13 PM), Tristan Timmer (09-30-2017, 12:41 AM), memloc (05-14-2017, 11:06 AM), Tshillingburg (03-28-2017, 01:56 AM), Frnandu Martiński (05-11-2017, 10:22 AM), egam (04-28-2017, 11:00 PM), skyfridge (03-22-2017, 08:56 AM), parabellum (03-22-2017, 08:15 PM), CrankyCoder (03-27-2017, 05:11 PM), tchipperfield (03-30-2017, 06:53 AM), Alec_J (06-22-2017, 07:47 AM), flight4900 (10-02-2017, 02:25 PM), Droid126 (05-24-2017, 06:36 PM), eAnic (05-16-2017, 02:53 PM), C11MAN (04-25-2017, 05:15 PM), jdeadman (10-01-2017, 12:40 PM), footgoo (03-28-2017, 08:23 PM), charlie246 (10-01-2017, 04:40 AM), Tomas To (04-26-2017, 08:05 PM), camils (05-07-2017, 05:59 AM), crud (11-05-2017, 02:46 PM), Zagy (04-10-2017, 04:09 PM), 2146 (04-25-2017, 07:49 PM), wim (10-01-2017, 01:30 PM), hugo5464 (04-08-2017, 08:58 PM), wimpie007 (06-25-2017, 11:15 PM), coconut2k13 (05-01-2017, 06:40 AM), MajStealth (05-19-2017, 08:56 PM), ericg (04-26-2017, 01:28 AM), frnandu (10-02-2017, 10:56 AM), melsom (07-30-2017, 02:11 AM), piscore (05-01-2017, 08:34 PM), Brian Drury (04-25-2017, 02:26 PM), typ49 (10-01-2017, 10:18 AM), VicRC (05-15-2017, 04:39 PM), Redmohawk (05-01-2017, 10:42 PM), The-J-Man (06-30-2017, 10:12 PM), Tommy Ng (05-26-2017, 01:42 AM), Hellonasty (05-28-2017, 07:20 AM), John (05-05-2017, 06:24 PM), Mo Sun (05-07-2017, 06:04 AM), Radi (05-25-2017, 12:05 PM), Alyas Junior Abdul (05-07-2017, 08:31 AM), Charles Francis Speakman (05-08-2017, 01:43 AM), kingofkya (05-10-2017, 12:18 AM), Jeremy Choy (06-21-2017, 07:06 PM), 1958 greyhound (06-21-2017, 07:53 PM), dnataemil (05-13-2017, 06:29 PM), Abarth595 (09-25-2017, 06:32 PM), Sentinal (06-06-2017, 07:54 AM)
