The finish-ish of a pcb based 14S 80P powerwall
Afternoon all,
Just a pic of the start of my powerwall.
Pcbs are my own design.
P.Tasyo Powerwall, Redpacket, Batrium And 11 others like this post
Modular, flexible, and professional finish.
1 kWp in Test
Ultra low cost
Interesting. Do you have anything to connect or support the battery boards on the opposite end of the main board?
(08-09-2018, 02:28 PM)Cherry67 Wrote: Modular, flexible, and professional finish.
Thanks.
(08-09-2018, 02:37 PM)Mazlem Wrote: Interesting.  Do you have anything to connect or support the battery boards on the opposite end of the main board?
I'm toying with the idea of using some kind of slotted apparatus, but those edge connectors grip well and the pcbs are the same height, so the shelf might just be good enough.
Also, if you need to grab something out quickly, the less in the way, the better.
Nice work .... looks good.
Is there some kind of cell level fusing ?
(08-09-2018, 03:35 PM)wim Wrote: Nice work .... looks good.
Thanks and yes, difficult to see, but there's a fuse wire between the two pads above each cell.
WuggyBuggy likes this post
I see ... you can even put glass fuses instead ... nice  Smile
grumble likes this post
Looks really nice and interesting cause I don't like the soldering on cells. Most likely due to my handling, I'm quite handy but soldering 18650's doesn't really go well for now.
Have you already been able to test out a full pack ? How is the heat dissipation at the terminals from the cell holders ? I remember Jehugarcia was experimenting with something similar and when he tested the pack under load, the terminals got way too hot.
So hopefully you're design got that sorted out and you're willing to share the PCB layouts ?
I certainly would be interested.
(08-09-2018, 09:34 PM)yoeri_w Wrote: Looks really nice and interesting cause I don't like the soldering on cells. Most likely due to my handling, I'm quite handy but soldering 18650's doesn't really go well for now.
No testing yet, but I'll let you know how it goes.
I saw Jehu's vid, but can't remember how many amps he was pulling.
I run a 48V system, so will spread the load to a minimum.
I'm sure to share if they work well.
Looks like a well thought out, neat and interesting design.
I hope testing goes well.
