  • 1 Vote(s) - 4 Average
CellLog 8 Discontinued?
I have the same problem. You can still get them though. Go to alibaba and order from the manufacturer directly...if you can. I have not experience ordering via alibaba.
Any update as to how this unit is working?
(04-07-2019, 04:53 PM)jdeadman Wrote: Any update as to how this unit is working?
I guess I forgot about this thread... I assume you are referring to the  ISDT BG-8S Battery Checker I said I would review.
I did some testing on the unit... it seems to be great.  I do like that it has a balance function, it has come in handy/useful, the accuracy seems pretty good too. Overall it was worth the purchase.
The iCharger 4010 was also an amazing purchase.  I do have some videos on the channel, its more than just a charger, its a complete battery workstation.  Very impressed with how powerful and useful both of these purchases were.
I made a short video which was about the Fiat cell, but also has a demo of the BG-8S.
Yea I was thinking on the Checker. i'll check out your vids. I am looking for something to keep an eye on some LTO cells
Do you know if the Voltage range is able to be custom configured? the LTO i'm using will run from 1.8v thru 2.8V
There is a menu for setup and options... ill take a look at that later and let you know if I see LTO as an option, or if there are settings for custom profile. I have not really explored that in detail.
One thing I did like about the CellLog is it had a dry contact output... could use that to trigger a relay or something to shutoff the load vs just alarm like most units.
Yea I love my Cellog8 and that it has a user settable parameters over alarms, max and min voltages and pack voltages.
I`ve got quite a few cell loggers i may consider selling if anyone is interested, i`ve got around 8 of them.
Based in the uk.
(04-08-2019, 05:04 PM)jdeadman Wrote: Yea I was thinking on the Checker.  i'll check out your vids.  I am looking for something to keep an eye on some LTO cells
Here are the available battery types from the menu... no custom voltage settings available.
Ahh Bummer no user settable. but thanks for that. the One cellLog I have will do I just need to build a multiplexer to switch between the 4 sets of cells Smile
(04-15-2019, 12:07 AM)Crimp Daddy Wrote:
(04-08-2019, 05:04 PM)jdeadman Wrote: Do you know if the Voltage range is able to be custom configured?   the LTO i'm using will run from 1.8v thru 2.8V
ummmmmmmmmmm, YES THERE ARE *shesh*.  there are a range of options to set warning voltages on the BG-8S ... no problem.  albeit 1.8V might be a bit on the low side.  IIRC 2.50V is the lowest setting ... but this is getting offtopic.
I have three of the iSDT BG-8S's ... love them.  BUT they are no celllogger .... the differences to me, are as follows:
1/ no alarm output
2/ no logging (obviously)
3/ no overvoltage alarm
4/ no out of balance alarm
I too, am seriously sad that I missed them before the supplies dried up.  The local (NZ) icharger agent/distributor here is both out of stock, AND too lame to explain or rectify.
And yes, the whole 'which cell it draws power from' bug has been squashed, long ago.  a new firmaware flash will fix this, I am led to believe.
Thanks to the posters/OP for this thread ... am now going to try again via ebay/OEM (SHENZHEN JUNSI ELECTRONIC CO.,LTD), and also ask glyndwr1998 if he still has any for sale.
jdeadman likes this post
