  • 1 Vote(s) - 5 Average
The Jehu PCB v1.1 Testing and Review thread
#41
(09-28-2018, 08:12 AM)lnxpro Wrote: are those made with M3 25mm standoffs? or M4 25mm ? or taller, like 30mm ?
M4X25Mm+6Mm Male To Female Thread Brass Hex Standoff
lnxpro likes this post
#42
Crimp Daddy what BMS are you using. I'm using this one. https://www.ebay.com/itm/7s-Cells-24V-20...1928469404 , With all the balance wire's on the pins. A B- to battery neg, A C- to charge controller neg.
#43
(10-09-2018, 12:53 PM)Peter T Wrote: Crimp Daddy what BMS are you using. I'm using this one. https://www.ebay.com/itm/7s-Cells-24V-20...1928469404 , With all the balance wire's on the pins. A B- to battery neg, A C- to charge controller neg.
I have a couple BMS boards including the one similar to what you linked, the BMS8 unit, and the PC / Bluetooth BMS boards which is what I an testing right now.  The Bluetooth BMS system I do like... having the ability to monitor and program the BMS adds a lot of value for me.
I haven't had time to really get into it, but my initial impression was positive.
#44
I have always been curious about those BMS. I might get a couple to play with.
Crimp Daddy likes this post
#45
I have found this link for the above bloothtooth BMS. https://www.aliexpress.com/item/7S-24V-1...36486.html
#46
(10-13-2018, 11:59 AM)Peter T Wrote: I have found this link for the above bloothtooth BMS. https://www.aliexpress.com/item/7S-24V-1...36486.html
I also have this BMS but for ebike.  For my 13S battery. Was rated 60A and cuts when reaches 40A, do not know why... But except that works great.
For Jehu's PCB, do you know where to get the latest layout? As I do not have FB account couln't get the layout... Thanks.
#47
Here's the official link from Jehu's kit page: https://www.amazon.com/clouddrive/share/...35com05-20
#48
You can download v1.3 from here
https://secondlifestorage.com/t-Jehu-PCB...rber-Files
#49
Thanks for the info. I just opened in the Gerbv app, sorry, first time I do this, I can see there are 8 layers, right? And if I go to the jlcpcb web site, I can see that I can select 6 layers max. So did a miss a step? Sorry one more time for really dummy question. Chris
#50
This PCB is only 2 layers. Top/Bottom layer for traces. There are no middle traces. So selecting 2 layers would suffice. Also, anything over 2 layers starts to get pricey
Unless the gerber is also referring to the silk screening and labels (?)
