  • 3 Vote(s) - 5 Average
Watts-on's "SpringSlot" 18650 Battery Holder
#31
Big Grin
(12-11-2018, 03:20 PM)watts-on Wrote:
(12-10-2018, 05:02 PM)chiphead Wrote: sorry  vitamin = non-printer parts in a printed project.
hardware.  The sizes and type of nuts and bolts etc.
Ah OK, not heard that term before.
I've edited the top post to included the "vitamins".  Smile
(12-10-2018, 05:02 PM)chiphead Wrote: Printing in eSun Black PETG on my enhanced FFCP
2 down 26 to go
Cool. Thanks for posting. Looking forward to seeing the finished product.  Smile
[Image: thumbsup.png]TYVM exactly what I was looking for.
IIRC  vitamins was used to describe the non-printed parts of the reprep.  it kinda stuck for printer projects.[Image: biggrin.png]
#32
2 down 26 to go
My hardware arrived from McMaster-Carr.
As a warning to others.  I ordered wooden cloths pins  from amazon and the springs fit but 3m screws do not.
Ordered some 2.5mm and hope they will fit as 2m are not available long enough.   Will update in a week once these arrive.
If they are still too big to fit my springs, I'll get some music wire and wind my own.
#33
++ Great thread and documentation. Really nice.
Edit:
Cell holders are definitely wear items if you think about testing thousands of cells like the PowerWallers before have done.
Regards,
Gary G.
Working on a 32 port #FCDS
24 ports complete... logging to Influx/Grafana
#34
(12-22-2018, 01:39 AM)chiphead Wrote: My hardware arrived from McMaster-Carr.
Sorry to hear you've had trouble sourcing the springs. Have you tried unwinding one of your springs by grabbing each end in some pliers and twisting by one turn in the opposite direction to the way its wound. This should open up the bore slightly.  I suspect it will distort the spring beyond use, but may be worth a try.
I didn't do any research into peg spring availability, but since I had these two types both of which are suitable I though it should be easy to find similar ones.
The green one is at least 10 years old and the blue one I bought only recently.
I trawled ebay and found a few that look remarkably similar, but obviously can't be sure they're OK.
PRO-MART-Plastic-Clothespins-24-Pack
NEW-Mainstay-52pc-Industrial-Strength-Plastic-Clothespins
96-Multi-Color-Plastic-Clothespins-2-7
HONEY-CAN-DO-Clothespins-Plastic-PK24-DRY-01390
If anyone sources suitable springs in their country, please post links here for the benefit of others.  Smile
Anyway hopefully your M2.5 screws will work OK <fingers crossed>
(12-22-2018, 05:02 AM)SecondHandPower Wrote: ++ Great thread and documentation. Really nice.
Edit:
Thanks SecondHandPower  Smile
Yeah, I had trouble with those standard holders with the formed contacts. When they're new I pretty much have to lever the cells out with a screwdriver, but then after a good few cells have been through them, they start to weaken and I start doubting if they are making a good connection. Then I have to tweak the contacts back to get good connections. Rinse and repeat. And thus was born the SpringSlot holder.  Cool
#35
2 down 26 to go
New hardware arrived and the 2.5mm work with my springs.   Pics to follow.
#36
OK  got my hardware in and the 2.5mm screws definitely work.
Love the design, however I have a suggestion.
We are installing the spring in reverse, ie against the designed springingness.  This weaken the spring action and over time I fear it will loose the strength to make a good solid connection.  I already over flexed one before it was mounted to a curcuit board and the spring is dead.  I'll have to tear it apart and replace the spring.
My suggesting is to modify the design to accomodate the spring in its natural state, ie the way its on the cloths pin rather in reverse.  I believe this will maintain the springiness of the spring better.  The holder will have to be a bit taller to accommodate the spring in that direction.  The part against the base will need a deeper recess.
Do you think this is possible?
-Wayne
#37
(01-04-2019, 02:55 AM)chiphead Wrote: We are installing the spring in reverse, ie against the designed springingness.  This weaken the spring action and over time I fear it will loose the strength to make a good solid connection.  I already over flexed one before it was mounted to a curcuit board and the spring is dead.  I'll have to tear it apart and replace the spring.
How are you reforming the springs? They should be unwound by approximately 80°
I can only speak for the springs I have access to, but the spring should be just as strong after reforming as it was before and the springiness works equally well in either direction. They are pretty strong and I don't see them losing their strength any time soon.  I predict they will outlast the 3D prints that I'm fitting them to.
If yours are not like that, then perhaps they are not made from suitable "springy" material. Confused
(01-04-2019, 02:55 AM)chiphead Wrote: My suggesting is to modify the design to accomodate the spring in its natural state, ie the way its on the cloths pin rather in reverse.  I believe this will maintain the springiness of the spring better.  The holder will have to be a bit taller to accommodate the spring in that direction.  The part against the base will need a deeper recess.
It's possible, but I think they would end up too large and bulky and would take more time and material to print them.  I think the quickest and cheapest solution may be to have another look around and see if you can source some alternative clothes pins.
#38
I understand your design and I am unwinding them  as you show.  That's my point unwinding instead of winding.  They are stronger spring action winding instead of unwinding.
My springs are just like yours just a smaller diameter of the wound part.
My goal is not cheapest.  heck a cheaper solution would be just two wires with magnets attached  but I'm not after cheap  Smile
I beleive using the spring in the other direction,  IE winding it a bit tighter rather than undwinding the spring would.
#39
hmm.. why do you believe the spring will not work in the unwinding direction? To my (possibly flawed) thinking, we are applying a ~30° twist to a 6.5 turn coil spring, so it should not care which direction the rotation is applied.
What do you have in mind for a way to use the springs unmodified?
#40
(01-05-2019, 11:04 AM)watts-on Wrote: hmm.. why do you believe the spring will not work in the unwinding direction? To my (possibly flawed) thinking, we are applying a ~30° twist to a 6.5 turn coil spring, so it should not care which direction the rotation is applied.
Well I don't have any scientific evidence but just my empirical observations.  To test my theory,  I reversed a spring in the cloths pin.  I don't have a way to measure the strength but clipping an unmodified pin to my finger and then the modified one and it feels significantly weaker.  after a few flexings a few dozen times its even weaker.   I'm sure if I could hook up a rig to test the strength it would confirm my observations.  I have already had one fail by flexing it just past vertical which I know once installed on a board won't happen but I didn't flex it far just slightly.  That's what lead me to the testing I have done.
You can try this and see if its the same for you.  just reverse a spring in the cloths pin.  Maybe its my springs as you suggested.  I have ordered a few different types of pins to test.
I was thinking if the base was thickened the diameter of the spring and the axil moved down the same thickness to keep the top of the coil lever with the bottom, the slot for the spring in the base would accommodate the spring in its original direction.  The whole thing would be just a bit taller ( the diameter of the coil spring)
