New powerpack 7S 22P
After building a 3S 60P, now made a 7S 22P.
This is last pack before starting the powerwall. Upgrades since pack 1:
 - spot weld negative site with nickel strips.
 - spot weld 3A glass fuses to pos. side and solder to busbar.
Capactiy of cells is between 1700 & 1900, have 700 higher capacity cells left for the 7S powerwall.
Spotwelder Sunko 709A
Have a nice weekend.
Frank
First pack 3S 60P as reference. Generated almost 30Kwh green DC energy this summer to power my XDSL modem, charge all mobile phones, tablet0, BT radios and a LED strip.
Headrc, hermitdave, hbpowerwall And 2 others like this post
I like the recycling and use of the old PC case... nice work.
hbpowerwall likes this post
will you add a bms to your pack? If so, which one?
(08-31-2018, 08:12 PM)yuri Wrote: will you add a bms to your pack? If so, which one?
Hi Yuri,
Please check first picture. In upper right corner I have a small BMS.
Used this one: BMS
Frank
Yes, sorry, Not seen it before. Thanks.
(08-31-2018, 06:47 PM)Crimp Daddy Wrote: I like the recycling and use of the old PC case... nice work.
me too.. its bloody brilliant.. I have a full ATX workstation which would be cleaned up and another case (from time when I built the xeon workstation) unused untouched.
Might have to measure the internals and see what I can do with them.
How do you charge it? Solar?
Yes solarcharged with 2x 100w panel and 7210A solarcharger. On a sunny day it generates easily +1kwh.
Hi Frank,
I've noticed that in the last picture you have a battery pack of a Gazelle bike laying on your power pack.
I have some too. But I have a hard time to get rid of the bus strips. When removing it leaves holes in the battery.
How do you remove the bus strips so that the battery doesn't damage?
Chris
(09-07-2018, 07:22 PM)Christiaan Plug Wrote: Hi Frank,
Chris
As with all stuck strips, just sip them flush. I use a sharp pair of sidecutters. You don't have to completely remove them. It is a common problem with many high current packs.
In fact, if a strip proves hard to remove at all, I just cut it off, leaving the spot welded pieces behind. Saves damaging the battery. They are particularly sensitive on the -ve end.
If you look closely at the photos you can actually see that much of the nickel has been left on the cells.
