Chuck's 18650 14S120P+1 UK Powerwall.
#51
Yeah
I've ordered my Sofar Mass Energy ME3000SP AC Coupled charger inverter.
So excited to get it all up and running.
jdeadman likes this post
UK Southwest.
#52
Yeah
Another box has arrived for me.
My new Sofar ME3000SP charger inverter has arrived.
Looking good.
Now to get it out up and running.
UK Southwest.
#53
Any particular reason you didn't go for the KTLM ?
#54
(08-25-2019, 10:06 AM)Sean Wrote: Any particular reason you didn't go for the KTLM ?
I think that’s a solar inverter only, the ME3000SP is an AC coupled bidirectional charger/inverter.
Would have preferred something in the 5-7 kW range but I couldn't find anything else that would suit my tight budget.
UK Southwest.
#55
Little update, work has been manic, not had much free time to spend on the wall but a little more work has been done.
Sofar ME3000SP is now hung on the garage wall.
Still need to install the critical loads board and wire back to the inverter.
Builder has been organised to come and build the battery house outside on the opposite side of the wall behind the inverter.
Busy printing mounts for the cell packs 20/28 printed so far. STL file, thanks to AZ Tekkie on Thingyverse. I won't be using the top mount as my packs are small enough not to require them.
Started work on the main busbars for the cell pack series/parallel connections.
I still need to finish the heat shrink and fit the clamps to 15 bars for the 28 x 40P packs built so far. You should get the idea from this pic.
There will be enough clamps for another 28 cell packs to be added at a later date.
Plan is to make it as easy as possible to pull a pack and replace it if/when required.
BMS monitoring leads will be connected to the top of each rod (eventually when funds permit it will be replaced will Batrium). Thinking about using a 15 core cable through the wall into the garage and mounting the BMS in an enclosure under the inverter. Unless theres any reason to have the BMS directly above the battery? I will need to extend the monitoring leads either way.
UK Southwest.
#56
Making progress with main busbars, 15 bars heat shrink sleeved with clamps ready to go.
Started to add link cables for pack connection.
Ran out of crimp lugs will need to pick some more up tomorrow, but cables are prepped with Anderson plugs.
Need to chase builder and find out when he's coming to build the battery house.
UK Southwest.
#57
Made a start on my little battery house.
Ground cleared
Slabs down
Walls up
Roof on and back wall boarded over. Busbars up ready for the packs.
BMS monitoring wires pulled in ready to be crimped to busbars.
Pack mounts going up tomorrow, I need to make the doors and fit them before putting the packs on their mounts.
Hoping to have an operational Powerwall by the end of the week.
jdeadman and Korishan like this post
UK Southwest.
#58
BMS cell monitoring wires connected up.
Pack mounts started going up.
Packs mounted and connected to the ME3000SP.
Was starting to get dark and beginning to rain, had to put the doors up a bit rapid so no pics of the packs mounted yet, maybe over the weekend if the rain stops long enough.
Still to sort out an issue with getting the ME3000SP talking to the BMS, not sure how this is going to work out at the moment.
Hanssing, ajw22, jdeadman like this post
UK Southwest.
#59
Very neat!
I've had seemingly rock solid 3d printed parts fail out of the blue after months of being under tensile stress. Maybe add some sort of backup clamp or strap as insurance?
chuckp likes this post
#60
(09-29-2019, 12:41 AM)ajw22 Wrote: Very neat!
Thanks for the heads up.
I have some metal L brackets that would fit in the recess on the underside, they would make great additional supports.
ajw22 likes this post
UK Southwest.
