Jadon Brenda
New member
- Joined
- Mar 28, 2017
- Messages
- 9
pulled some cells that were at 3.7v but were next to a 0V short cell and the positive is a little corroded and nasty, would you clean it up and rewrap or is any corrosion cause to huck it?
daromer said:I would throw them if the voltage is 0. If the voltage is 3.7 or around i would clean them and stick them into a "Need to test bit more and use for 2ndary stuff"- bin.
I got plenty of cells as of now and therefore i rather throw some extra cells than dont....
JadonBrenda said:pulled some cells that were at 3.7v but were next to a 0V short cell and the positive is a little corroded and nasty, would you clean it up and rewrap or is any corrosion cause to huck it?
