Batrium: software & firmware update
(09-30-2018, 09:43 PM)daromer Wrote: As I said I can see V30 on WM1. Thats the latest set out on the autoupdater as it looks.
Cheers, I though that's what you'd said  Smile
Mine is throwing the same message.
Haven't hooked it up to wifi yet, but I got USB working after some jiggerh pokery.
Background the software/firmware releases are dependant on the version of hardware that you are running
  • Watchmon1  - stable (production)  release 1.0.30
  • Watchmon4  - stable (production)  release 1.0.31
For public releases we are trying to group them into 3-6 month scheduled updates to be less disruptive to our customers.
There are 3 stages to each release:
  1. Alpha -  (Release Candidates) these should only be used when instructed by Batrium staff to test new functionality.
  2. Beta   - released several weeks prior to live (production) to evaluate stability and any unexpected issues, this is targeted for earlier adopters
  3. Live   -  the stable production version available
Currently we are working on 2.0.6 (RC6 for short) with new features and fixes. However it is not quite ready, we are working on a important issue with the shunt lockup reported from 1.0.32RC3, that is taking time to resolve. The Shunt lockups occurs after +30 hours. On our test bench we have several Watchmon supervisors all at different operating durations to ensure we solve this. Once resolved I can push out RC6 for the very early adopters.
New options within the software update in 2.0.6
BETA release
ALPHA release
www.batrium.com provider of battery management for lithium cells
Thank you Jaron, interesting and concerning.
As per my initial post, is the mismatch shown in this threads initial image expected ?
Also, the teensy update now runs, and completes - running the firmware updater appears to keep repeating the same process. Will it only complete this process is there is a newer firmware version available?
Since running the firmware update, I'm prompted that bypass testing isn't complete, but fails, as does device sync (starts but doesn't complete) stays in polled mode, collection running.
Chart only showing 1 of 12 mons.
Restarts appear to have no affect.
So, a coffee later, device sync now completes, chart reporting all mons - bypass fails on all mons (each at 4.08v 7c)
Preset version 1
Hw v 4.2
Fw v 4.1
Sw v 31
So, out with the heat gun to warm the mons slightly, results in an 11/12 bypass success - the remaining 1 has always been troublesome.
Is there a "don't run bypass test if temp is less than ?" setting ?
I'm not sure if I've made any forwards progress in the last hour with this, but perhaps these notes will help others.
You can change the temperature for the bypass test so you pass Smile (I do that) With that said 7c is low temp Tongue
(10-01-2018, 03:30 PM)daromer Wrote: You can change the temperature for the bypass test so you pass Smile (I do that) With that said 7c is low temp Tongue
7c is still tee shirt weather here.
HughF likes this post
I'm returning home today wondering if the batrium firmware update Is now out as will be putting powerwall back into service tomorrow
(10-27-2018, 08:11 AM)ardenking5 Wrote: I'm returning home today wondering if the batrium firmware update Is now out as will be putting powerwall back into service tomorrow
I've heard/seen nothing ....
Check here, released just yesterday...
https://www.batrium.com/blogs/news/watch...se-2-0-rc7
ardenking5 likes this post
has anyone tested this yet ?
100 User(s) read this thread:
hbpowerwall (06-10-2019, 10:31 AM), daromer (06-04-2019, 04:53 AM), Sean (06-04-2019, 08:21 AM), mike (06-04-2019, 01:51 AM), Korishan (06-04-2019, 01:57 AM), PAF (10-31-2018, 02:56 PM), Batrium (11-02-2018, 06:54 AM), Frnandu Martiński (06-05-2019, 09:26 AM), Mike C (11-03-2018, 09:07 PM), jdeadman (06-13-2019, 01:51 AM), wim (06-04-2019, 04:03 PM), wimpie007 (10-31-2018, 02:34 PM), watts-on (06-04-2019, 09:31 AM), jesusangel (10-21-2018, 06:23 AM), Stefaan De Ridder (09-30-2018, 04:41 PM), Chiptosser (05-31-2019, 12:25 PM), KtB (05-31-2019, 09:09 PM), Geek (06-04-2019, 03:45 AM), Jon (10-30-2018, 10:46 PM), Bloater (10-29-2018, 06:58 PM), floydR (10-01-2018, 10:21 PM), Chris Jardine (06-05-2019, 11:19 AM), emerca (11-04-2018, 02:53 AM), ChrisD5710 (06-04-2019, 09:18 AM), ardenking5 (10-29-2018, 11:25 AM), Oz18650 (06-10-2019, 09:24 PM), CarelHassink (06-04-2019, 10:06 AM), Filip (06-03-2019, 07:11 PM), Solexx X (10-28-2018, 05:06 PM), Charly144 (10-21-2018, 06:40 AM), djuro (05-31-2019, 03:03 PM), Scubasteve04 (11-08-2018, 04:57 PM), Lindsaymac1 (06-08-2019, 12:13 PM), brwainer (11-05-2018, 12:03 AM), drchips (10-01-2018, 03:50 AM), cat23 (10-07-2018, 05:26 AM), HughF (09-26-2019, 08:56 AM), nrm21 (12-08-2018, 02:27 AM), rtgunner (11-02-2018, 04:03 AM), outerlimits (01-06-2019, 02:25 PM), EGOksy (11-13-2018, 11:55 PM), phikzel (03-05-2019, 02:03 PM), mbrunton (10-02-2018, 11:51 PM), TeddyandJ (10-30-2018, 01:59 AM), babish (11-23-2018, 02:28 PM), Redpacket (06-04-2019, 03:17 AM), mldee (10-29-2018, 07:56 AM), Zvonko000 (08-08-2019, 05:07 PM), Oliman (06-04-2019, 11:43 PM), whisperbot (07-18-2019, 07:14 PM), farmerjohn (07-07-2019, 04:48 PM), cadric (09-15-2019, 03:21 PM), Cherry67 (06-04-2019, 11:49 AM), Scrud (11-20-2018, 04:14 PM), Sholphin02 (10-29-2018, 11:46 PM), Walde (11-06-2018, 12:54 PM), Riplash (06-04-2019, 03:37 AM), w0067814 (09-30-2018, 09:55 PM), Rick88 (10-21-2018, 06:24 AM), michaell (06-06-2019, 10:22 AM), Finihen (12-04-2018, 03:46 PM), yoeri_w (10-27-2018, 09:18 AM), chuckp (11-02-2018, 06:03 AM), DutchDIYPowerwall (07-15-2019, 09:15 PM), Chass90 (10-03-2019, 08:41 AM), Patrick St-Onge (11-17-2018, 11:18 PM), runsnbunsn (10-04-2018, 07:30 PM), deniscroombs (12-02-2018, 09:35 PM), Wolf (06-04-2019, 11:55 AM), Bastler_Ro (06-04-2019, 11:42 AM), |3lksw (11-01-2018, 09:39 AM), camthecam (10-29-2018, 11:05 AM), jeffl98 (11-02-2018, 04:38 AM), hellhole (10-28-2018, 09:51 AM), Generic (06-04-2019, 05:02 AM), Bayyn (10-30-2018, 08:14 AM), vieira.pedro (12-07-2018, 02:54 PM), BigDav (11-09-2018, 10:27 PM), dwessels (11-10-2018, 08:32 AM), ajw22 (06-02-2019, 10:29 PM), BmoreThor (06-02-2019, 07:10 PM), newone972 (10-15-2019, 11:03 AM), Rohmad (12-03-2018, 12:59 PM), kevinjaye (07-15-2019, 07:30 PM), oloyeadeniran (06-13-2019, 08:00 AM), OffGridInTheCity (05-31-2019, 03:43 PM), sandroth (12-27-2018, 01:24 AM), zoookii (05-31-2019, 08:25 PM), dealbidz (12-31-2018, 03:19 AM), sparkgap (06-04-2019, 09:00 PM), Tobeabrepper (04-12-2019, 02:45 PM), oel_mangahas (02-08-2019, 05:04 AM), juanjo57 (08-17-2019, 09:47 AM), sgrevskott (03-21-2019, 08:56 AM), gpearce52 (05-07-2019, 11:47 PM), Moo (05-31-2019, 11:12 AM), Jagath.Madona (06-05-2019, 05:01 PM), doctorjkill (06-12-2019, 06:15 AM), OzfromAUS (06-17-2019, 12:22 AM), bigmac5753 (06-30-2019, 05:24 PM)
