Korishan
Administrator
- Jan 7, 2017
- 7,538
I was thinking, these microinverters are expensive. Could it be done that you could make one from an arduino nano/mini (or equiv) and some mosfets, i2c connection, voltage/ampere meter, and a little bit of programming?
My thinking is that, AC is AC. It bounces back and forth at a certain frequency by a certain amplitude. The only reason why it's a "wave" form from the power company, is because the power is generated by a rotating electrical field.
A simple DC-to-AC converter would be two PWM's inverted to each other. We could use a similar set up that Julian used in his setup, but using a nano instead of a mega or full sized board.
We would have a master in the shed (or other central location) that would send a sychronizing command to the micro's so they oscillate at the proper frequency. Back in the shed, we would use a bridge rectifer to convert back to DC voltage.
Each micro would also report back to the master what's going on with it; voltage/ampere, temperature, performance, even angle of panels if equipped with a tracker.
If this can be done, it would drastically reduce the cost of installed solar in bulk and getting every drop out of them w/o worry of 1 panel/cell shorting out the others.
Whadda think?
Whadda think?
