Dennis' 14s200p x 2.
Started spotwelding my packs.
Redpacket likes this post
What did you use for spot welding ?
WuggyBuggy likes this post
(03-01-2019, 11:49 AM)Overmind Wrote: What did you use for spot welding ?
Sunkko 709AD+ :Smile
Great tool!
Last finishing touch... glass fuses =( Haven't been to exited about this... but it w<quite fine and I thought it took longer to do the first 20. (Update: To do a pack with 200p, it takes around 2 hours for the fuses)
I know it's not as pretty as I want... but its the first 20... soo Big Grin  Cool
Also did the bottom side of the pack. Had some help from the guys on Discord. Mazlem, Phizicks, Korishan, Keith (shrink18650)
Everybody else there, is so kind to answer all kinds of stupid questions and also good to bounce some ideas off. So thanks!
So.... ATS is installed.
First thing to use this for: To rep on the inverter, if there should be a problem.
Second: Overload on the inverter. When cooking for a few more ppl than the wife and me.
Finaly I have 14 packs ready with plugs and everything.
I just can't deside if I should wait for the WatchMonElite, or to buy the WatchMon4? Really want this setup up and running. Ack! Batrium said it should be out this year.... yeah okay... still 6½ months left of it.
Would you guys say it is worth to wait? I mean, for what I've read on batrium.com about the WatchMonElite, it should be awesome. Don't have the WatchMon4 to compare.
I've painted the plugs myself (Cheaper). Also new layout on the pack. No need to twist 2 x 6mm2 cobber wires. So now I have 1 x 6mm2. That will take around 43A.
Still need some shrink on end here.
Little Crimp tool I borrowed from a friend. Check it in action here (Google Drive video):
https://photos.app.goo.gl/yhY9ErWukByFrbo46
Very impressive and well done!!!!
I can only hope that i will end up with a set like you have.
You come this far, what is 6 months??
Best
(05-16-2019, 05:26 AM)100kwh-hunter Wrote: Very impressive and well done!!!!
Best
Thank you very much sir. What setup are you going for?
Yes, you are absolutely correct. I'll wait for the new version of the Watchmon.
#29
I think when your cells are good sorted the Watchmon4 with longmons is still enough.
My 14s100p Powerwall needs nearly no balancing.
So I think the 94Ah balancing power per day which the Watchmon Elite can handle is only nessasary for much bigger systems.
#30
(05-16-2019, 09:36 AM)jaeger-audiodesign Wrote: I think when your cells are good sorted the Watchmon4 with longmons is still enough.
That is a good point. Also one thing I liked about the elite, was no daisy chain. But yeah, why would you mess around with it everyday.
