lifepo4_powerwall
- Aug 11, 2018
- 10
I need some help confirming the wiring on this project.
To recap from other postsI have 10 packs of LiFePo4 calls, each with 12v in 4s19p arrangement.
I am going topower a 6000w 24v inverter to run loads in the house when I lose power during a storm in Florida. I have an interlock which isolates the line supply when I use this inverter. I connected each pair of packs to get 24v.The nickel strips on the picture below links two packs for 24v. For simplicity I'll ignore the Headway38120 cells under the blue inverter.
During a normaldayI also want to run a 1500w12v inverter so I have wires coming off each pack to powerthis inverter. This inverter will run some loads in my house such as my office equipment in the day while my 4 renogy 100w panels charge the array.
All wire runs are the same length and I up sized the wire AWGa bit to lower losses.
My concern is the wiring the 12v inverter and the 24v inverter. Is this going to work without frying my 12v inverter?The red and black wires are for the 12v inverter. Wiring for the 24v inverter is not shown (they connectat the top of each pack).
Also how can I attach these voltage meters?I can't figure outa screw small enough.
Thanks for the guidance.
Andrew
Andrew
