Tenergy LR1865S1 Cell Specifications
TheBatteries
Administrator
Brand:Tenergy
Model:LR1865S1 (ICR18650-2200)
Capacity:2200mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1100mA Standard
2200mA Maximum
Discharging:3.00V Cutoff
--- mA Standard
4400mA Maximum
Description:Grey Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.tenergy.com/30023-1
Pictures:
I think model should actually be LR1865SI ("I" instead of "1").
I have this same cell model without any "Tenergy" lines at all.
