Power_Fabi
New member
- Joined
- Apr 9, 2017
- Messages
- 1
Hello everyone!
I recently thought about an interesting idea to build powerwall.
For a lot of other 18650 build I often sourced powerbanks. Most of the times Xiaomi 10.000mah powerbanks which contain 3 cells with 3250 mAh(LG or Sanyo). These powerbanks can often be found for around 10Usd - which equals 3.33Usd per Cell.
So why not use the Powerbanks as they are and connect them via a Usb harness?
Each Powerbank outputs 5V at 500mah (but there are others which can output up to 2A). You could connect as many powerbanks as needed in series/parrallel to reach the desired voltage/amps.
Due to the internal step op convertet that boost the voltage up to 5V the efficiency obviously sinks. Therefore the powerwall would get more secure due to the internal cell control of the powerwall.
What do you think?
What do you think?
