  • 4 Vote(s) - 4.5 Average
AJW22's modular 3d printed 60kWh PowerShelf
#81
In response to a request: here are my postgresql db structure and my latest grafana dashboard export.  Note that I'm still experimenting with stuff, so it's ugly and some weirdness may be going on.
note:
* All data stuffed in just one table for now
* values are stored as integers of mV/mA, in hopes of improving performance... not sure it did
* battery_id(0) entries contains the sum/average of all batteries
.zip   postgresdb_grafanadash.zip (Size: 7.6 KB / Downloads: 28)
#82
(08-05-2020, 04:49 AM)ajw22 Wrote: In response to a request: here are my postgresql db structure and my latest grafana dashboard export.  Note that I'm still experimenting with stuff, so it's ugly and some weirdness may be going on.
note:
Thank you so much!!
ajw22 likes this post
#83
Awesome progress BobinTN and AJW22 and thanks for the initial source code as shared with AJW22
(03-22-2020, 02:18 PM)BobinTN Wrote: BMS Python Code implementation update:
AJW22!  It is going well.  I am not complete in implementation, but it is taking awhile so I figured I owed you an update.
I am now testing your code on my 3 china BMS's.  I collected from one for awhile playing with the Influxdb/Grafana component.
There seems to be some instability in the Bluetooth (I don't quite know where it is coming from {rpi, linux, bluetooth comms, influxdb...}).
How do you run your python code?  from IDE, from command line, daemon...
Do you have a restart script to monitor the main code?
I am not asking for code, just wondering.  I have been looking for a script restart after failure solution.
Can you share the updated source code? I am in the stage of adding the BMS and start playing monitoring and graphing.
Thanks
#84
Here's my latest code for fetching data from my 6 BMSs and storing them on a postgresql db.  Really really in need of a ground up rewrite...
Also a script to control the TPLink HS105 smartplug.
BMS notes/changes :
* My USB bluetooth dongle by CSR (aka Cambridge Silicon Radio) could not connect to 6 BMSs at the same time, so I have 2 USB BT dongles (hci0 + hci1) sharing the load.  Onboard BT is disabled.
* 5 minute collection interval is ok for logging, but a little slow for switching loads.  So near real time data is stored in "/dev/shm/bms.txt"
Smartplug notes/changes :
* tries a couple of times in case of connection error.
* Reading the current status is possible, but I've not coded it yet.
.zip   bms4_smartplug.zip (Size: 4.23 KB / Downloads: 31)
#85
(08-06-2020, 10:15 AM)ajw22 Wrote: Here's my latest code for fetching data from my 6 BMSs and storing them on a postgresql db.  Really really in need of a ground up rewrite...
BMS notes/changes :
Thanks, will test it and revert
#86
Besides increased BMS cost, what are the downfalls of doing 3x 14s100p instead of 14s300p?
I like the idea of being able to add capacity 1400 cells at a time vs 4200....
#87
(08-31-2020, 07:05 PM)mtucker502 Wrote: Besides increased BMS cost, what are the downfalls of doing 3x 14s100p instead of 14s300p?
More work wiring everything up. Particularly creating my main battery harness with all the sensing/balancing wires is a pain in the a$$. But that's a one time work that saves time and effort later during maintenance.
I might go for 120p or 140p for my last batteries, to fully utilize my rack space and have a bit more capacity.
Otherwise very happy with the smaller packs - it's really helpful to be able to pinpoint problems down to 100 cells, just by looking at my graphs!
mtucker502 likes this post
#88
Wouldn't there be issues having 14s packs with varying capacities? or will the new shelf not be connected in parallel to the 14s packs on the first shelf?
#89
(08-31-2020, 11:11 PM)mtucker502 Wrote:
(08-31-2020, 10:33 PM)ajw22 Wrote: I might go for 120p or 140p for my last batteries, to fully utilize my rack space and have a bit more capacity.
No, it's not a problem.  In fact, my first battery is 14s96p with just 120Ah (shitty cells) or so and the others 14s108p, one with nearly 190Ah!
Not even a problem with a much larger difference, say a 14s300p.  It would simply supply/draw 3x more current, but the voltages will all equalize. Just need to make sure the BMS, breakers, and wires can handle that extra current.
