Re-Volt ICR18650-2600 Cell Specifications
Brand:Re-Volt
Model:ICR18650-2600
Capacity:2600mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
3000mA Standard
--- mA Maximum
Discharging:3.00V Cutoff
0mA Standard
10000mA Maximum
Description:Pink Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
Datasheet.
I tried to avoid making jokes about this cell.
If you assemble a pack with it will it start a rebellion?
When you charge it does it smell bad?
Would you trust anything with such a revolting name?
Somehow I think that is enough of my revolting jokes...  Tongue
Attached the spec sheet, link Geek posted is down. Standard discharge is 520mA, max charge is 7800mA.
.pdf   Re-Volt-18650-Spec-Sheet.pdf (Size: 320.43 KB / Downloads: 489)
