Processed Submissions and Updates
#91
Brand: LG
Model: LGDBMG11865
Capacity: 2900mAh Rated
1650mA Standard
10000 mA Maximum
Description: Light purple
White Insulator Ring
Note: Added, thank you!
mike likes this post
#92
Found these in a supposedly 14.8V and 2600mAh laptop pack. But pretty sure that was all bullshit considering the cells have 2000mAh written on them. But they seem to be similar to the other FST models in the database so far, just with different capacity and slightly different color.
Brand: FST
Model: 18650-2200mah (?)
Cell Color: Blue
Insulator Ring: White
Capacity: 2200mAh
Nominal V: 3.6V
#93
Database have grey, found another wrap color.
Brand - Moli Energy
Model - ICR-18650G
Wrap color - Turquoise
Ring color - Black
Note: Added as a variant of the current entry. Thanks!
#94
Here are 2 I did not find in Database
#1 Sanyo UR18650P
Info https://www.master-instruments.com.au/fi...18650P.pdf
Sorry for the screwdriver prop. Dodgy
#2 Cham Battery Technology Co.,Ltd
Info https://cylindrical.en.ec21.com/18650_Cy...54156.html
Last count as of 8/7/2019
For Info Google Drive
#95
UR18650A I have a bunch of them Tested at 2334mAh with 40mR on the Zanflair and 2249mAh with 38mR on LiitoKala.
https://www.ebay.com/itm/4PCS-Original-S...ctupt=true
Note: Created database entry. Please submit some pictures in a stadandard uncropped aspect ratio, such as 4:3. Thanks.
Cherry67 likes this post
#96
Sony US17670GR
Note: Created entry, couldn't find any reliable data.
#97
Samsung 20F cells out of an E bike pack.
hbpowerwall likes this post
#98
LGEBMG11865   (e-bike pack)
2850 mAh
Light purple, white ring
standard voltage: 3. 6v discharge cut-off voltage: 2. 5v discharge current: max. 10a
ChrisD
Note: Please take some pictures. We can't use pictures from the internet.
#99
LGEBMJ11865
from E-Bike Bosch POWERPACK 500 FRAME
3.7V 3500mAh LG 18650MJ1 battery supply by UNICELL in Singapore
UNICELL a Leading battery product supplier in Singapore Malaysia Indonesia Philippines Brunei and Thailand since 1986, we carry more the 66,000 model
Order code: LG18650MJ1 (LG 18650-MJ1 battery)
3.7V 3500mAh 10A LG 18650MJ1 Li-ion battery
Specifications
Voltage: 3.7V
Capacity: 3.5Ah / 3500mAh
Size: Dia. 18mm x Height 65mm
Cut off Voltage: 2.75V
Full charge Voltage: 4.2V
Max. Discharge Current: 10A / 10000mA
Battery Info
From a dell laptop battery type W1193
