Processed Submissions and Updates
LGDAME11865
Brand: LG
Model name(s): LGDAME11865,ICR18650ME1
Weight 43.60 g
Diameter, max. 18.30 mm
Height, max. 65.00 mm
Voltage, charge max. 4.35 V
Voltage, nominal 3.75 V
Capacity, max. 2100 mAh
Constant charge current, max. 2.10 A
Charge constant standard 1 A
Max. continuous discharge current 4.20 A
Peak discharge theoretic, 4 sec 7.35 A
C-rate (charge, max.) 1 C
C-rate (discharge, max.) 2 C
Watts (charge, max.) 7.875 W
Watts (discharge, max.) 15.75 W
Energy, max. 7.88 Wh
Density volumetric theoretic 461 Wh/L
Density gravimetric theoretic 181.00 Wh/kg
E-rate (charge, max.) 1 E
E-rate (discharge, max.) 2 E
NMC
Cathode LiNiMnCoO2
Anode carbon
Temp charge, min 0.00 °C
Temp charge, max 45.00 °C
Temp discharge, min -20.00 °C
Temp discharge, max 60.00 °C
Internal impedance 6 mΩ
Note: Added, thank you!
This cell is not in the database. Can anyone tell me about it and put it up?
https://eu.nkon.nl/rechargeable/18650-si...00mah.html
Note: We need pictures that you have taken before we can create a cell database entry.
Sanyo UR18650A WHITE RING
Note: Pictures Added, Thank You!
Sanyo R1112 from Yamaha EC-03 2011
Note: We need higher quality pictures please...
Hi, I came across an LGDAHD41865 cell and cant find any specs. Going to do a capacity test when I get home and will update.
Thanks
mike and hbpowerwall like this post
LGABHG21865
(11-22-2019, 09:54 AM)Jesse Wrote: Hi, I came across an LGDAHD41865 cell and cant find any specs. Going to do a capacity test when I get home and will update.
Thanks
Looks like an LG HD4, power cell 2.1AH 25A: https://www.imrbatteries.com/lg-hd4-1865...p-battery/
Note: Already got it, thanks!
Found some LG cells that don't appear in the database. LGABD21865. Found in two Dell 65 Wh laptop packs (P/N 04KFGD). All tested right around 3000 mAh and around 50 milliohms.
(11-29-2019, 05:43 PM)cowpen Wrote: Found some LG cells that don't appear in the database. LGABD21865. Found in two Dell 65 Wh laptop packs (P/N 04KFGD). All tested right around 3000 mAh and around 50 milliohms.
LG D2 cell, here's a data reference: https://www.batteryjunction.com/lg-d2-battery.html
Note: Got it, thanks!
I guess this are some Sanyo cells. No print or stamp at the isolation.
Just printed dirctly on the cell:
"IQFJT
090402"
red wrapping and red isoilation ring.
Note: We need a model number to create a listing. They look like they might be UR18650FJ but unable to confirm with certainty.
