Processed Submissions and Updates
looks like I'm a day late with these pics. oh well.
INR18650-13Q
Note: Added, thank you!
mike likes this post
Found 4 of these LG cells, three of them tested over 2900mAh !
Make/Model: LG LGABC41865 (INR18650C4)
Capacity: 2850mAh
Nominal Voltage: 3.65v
Charge Voltage: 4.20v
Charge Current: 1375mA
Discharge Voltage: 2.75v
Discharge Current: 550mA (is this right? am I reading the data sheet correctly?)
Wrap Color: Chocolate (brown)
Ring Color: White
Datasheet Links:
www.cleon.ru/specification/LG-INR18650C4.pdf[url=www.cleon.ru/specification/LG-INR18650C4.pdf][/url]
Pictures:
Inr 18650-15k Samsung's, data sheet also included, , capacity too low for me but eh,
Out of an old drill pack
.pdf   INR18650-15K.pdf (Size: 772.75 KB / Downloads: 58)
Note: Thanks, but can you try to grab some higher quality pictures please?
Moli IBR-18650B, once again out of a drill pack, and again only 1500mah new, but, more knowledge for everyone else. Data sheet attached again,
.pdf   6661.DM_IBR18650B.pdf (Size: 101.99 KB / Downloads: 70)
These battery are like the YikLik (YLE) INR18650A220 But the wraping is orange and the ring color is black. And the model is :YikLik (YLE) ICR18650A220
This is what i found out of the specs of the battery.
https://www.ecvv.com/product/2811976.html
I hope this is done the correct way.
Make/Model: Sanyo/Panasonic UR18650W2
Capacity: 1500mAh
Nominal Voltage: 3.70v
Charge Current: 1050mA (Std.)
Discharge Current: 300mA (Std.)
Wrap Color: Red
Ring Color: Pink
Datasheet Links:
http://www.datasheet.jp/download.php?id=1006973
Pictures:
LG
LGCH118650
Hi Mike,
found another one that's not in the database, yet:
Make/Model: Moli ICR-18650J
Capacity: 2370mAh
Nominal Voltage: 3.76V
Charge Voltage: 4.20V
Charge Current: 2400mA (Max.)
Discharge Voltage: 2.5V
Discharge Current: 5000mA (Max.)
Wrap Color: Purple (sometimes blue)
Ring Color: Black
Datasheet Links:
http://www.meircell.co.il/files/Moli%20ICR18650J.pdf
http://www.houseofbatteries.com/documents/ICR18650J.pdf[/url]
[url=http://www.rccd.org/Documents/Tips/2012_04_ICR-18650J.pdf]http://www.rccd.org/Documents/Tips/2012_04_ICR-18650J.pdf
Pics:
keep up the good work :-)
Oliver
Cells tested: 6.234 (overall: 12.414 Ah, average: 1.991 mAh)
Cells in production: 3.360 (overall: 7.056 Ah, average: 2.100 mAh)
Powerwall setup: 7s480p, 1.008 Ah, 26 kWh
Project page
Live solar/powerwall values
Daily graph
next new cell:
Make/Model: Moli ICR-18650K
Capacity: 2600mAh
Nominal Voltage: 3.7V
Charge Voltage: 4.2V
Charge Current: 1800mA (Std.) - 2600mA (Max.)
Discharge Voltage: 3.0V
Wrap Color: Purple
Ring Color: transparent blue
Datasheet links:
http://www.molicel.com/hq/product/DM_ICR...-80054.pdf
http://www.all-batteries.es/media/pdf/ES/ACL9301.pdf
Pics:
Project page
Daily graph
Sony US18650VT cell
