Processed Submissions and Updates
#31
any good  for database?
Toshiba.
http://pdf.datasheet.live/12150411/toshi...R17500.pdf
Still testing but coming up 1000mah so far.
Note: Added, thank you!
mike likes this post
#32
A colourful one for the  database
Brand: Sanyo/Panasonic
Model: UR18650ZTA
Capacity: 3000mAh Rated
Voltage: 3.7V Nominal
Charging: 4.35V Maximum
1450mA Standard
? mA Maximum
Discharging: 3.0V Cutoff
?mA Standard
?mA Maximum
Description: Purple Cell Wrapper
Yellow Insulator Ring
18650 Form Factor
Datasheet link
https://na.industrial.panasonic.com/site...650zta.pdf
B18650CA
Brand: BAK
Model: B18650CA
Capacity: 2250mAh Rated
Voltage: 3.60V Nominal
Charging:
4.20V Maximum
1100mA Standard
2200mA Maximum
Discharging:
2.75V Cutoff
1100mA Standard
2200mA Maximum
Description: Green (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://eleven1100.sell.everychina.com/p-...ttery.html
No datasheet found but there is a photo  at
 http://www.bak-energy.com/pro_show.aspx?Id=21
#33
Not sure how this is to be laid out
INR18650-13P
Samsung SDI
[b]Capacity 1300mAh[/b]
[b][b]Discharge 10A[/b][/b]
Battery Specs
That is all I could find on these.
#34
Brand:
Sanyo
Model:
UR16650ZTA
Capacity:
2330mAh Rated
Voltage:
3.70V Nominal
Charging:
4.35V Maximum
1190mA Standard
--mA Maximum
Discharging:
3.00V Cutoff
1210mA Standard
4840mA Maximum
Description:
Purple Cell Wrapper
16650 Form Factor
Datasheet : https://www.tme.eu/fr/Document/b79073600...650ZTA.pdf
brettwatty likes this post
#35
LGDAS4165:
No details, except it's a 2200 mah
Hydroélectric 800W PELTON Générator - 6 x 270W solar Panel
Oct 2017 : 850 cells collected : Test in progress
#36
Submitting LG 18650 S4 cells
Refrence : LGAAS41865
Wrap purple
Ring white
Capacity : 2200 mAh
Max charge : 4A
Max discharge : 4.4A
Cut-offs : 2.75 / 4.2
The only found link : https://wholesaler.alibaba.com/product-d...15285.html
#37
Seems to be a Sanyo cell but no URxxxxxx stamped on wrapping.
Red Wrap, Red ring
F stamped at the bottom
Up to 2250 mAh after testing
Note: Thanks, but we can't do anything with them without a model number.
#38
HM ICR18650PA W1K1808-D
#39
Hi,
Just came across a variant of Samsung ICR18650-22F that doesn't seem to be referenced, namely ICR18650FM:
I got them in an aftermarket battery :
As one can see, another marking can be read through the green plastic :
Many sites seem to sell them, and the datasheet is attached (found on mantech.co.za)
Keep on the good work,
Vincent
.pdf   INR18650-22FM.pdf (Size: 229.22 KB / Downloads: 80)
#40
I found this one today : PANASONIC ? CRN18650 2200mAH 3,7V : fruit green
