  • 1 Vote(s) - 5 Average
Processed Submissions and Updates
#21
LG LGDAHA11865
http://www.staringpower.com/product/lgda...0-1300mah/
Note: Can you please retake the pictures in a normal aspect ratio? Thanks.
#22
LGEP218650
Only detail I couldĀ get via Google was they have 2500mAh capacity
Note: Already have these, thanks!
#23
PANASONIC NCR18650D
Note: Added, thank you!
mike likes this post
#24
CGR18650CF
Note: Added pictures, thanks!
#25
Make/Model: LG LGDBB41865 (LG ICR18650 B4)
Capacity: 2600mAh
Nominal Voltage: 3.60v
Charge Voltage: 4.20v
Charge Current: 0.5C (Std.) 1C (Max.)
Discharge Voltage: 2.75v
Discharge Current: 0.2C (Std.) 2C (Max)
Wrap Color: Grey
Ring Color: White
Datasheet Links:
2 differents files linked
https://www.neuhold-elektronik.at/datenblatt/N6102.pdf
https://www.neuhold-elektronik.at/datenblatt/N6102_.pdf
Pictures:
#26
Make/Model: Panasonic NCR-18650E
Capacity: 2250 mAh
Nominal Voltage: v
Charge Voltage: 4.2v
Charge Current: 4200 mA
Discharge Voltage: 2.0v
Discharge Current: 10 A
Wrap Color:
Ring Color:
Datasheet Links:
http://actec.dk/media/wysiwyg/Actec/PDF/NCR-18650E.pdf
Pictures:
none yet
Note: Need pictures before we can create database entry.
#27
Hi Mike,
here's a datasheet link for BAK 18650C4: http://www.ebike.ir/uploads/GB%20cell%20spec.pdf
Note: Updated, thanks!
Cells tested: 6.721 (overall cap.: 13.587 Ah, average cap.: 2.021 mAh)
Cells in production: 3.500 (overall cap.: 7.350 Ah, average cap.: 2.100 mAh)
Powerwall setup: 7s500p, 1.050 Ah, 27 kWh
Project page
Live solar/powerwall values
Daily graph
#28
Add
Make/Model: FST / 18650-2200mah
Capacity: 2200 mAh
Nominal Voltage: 3.6v
Charge Current: 1100 mA (Std.) / 2200 (Max)
Discharge Current: 2200 mA (Std.) / 8800 (Max.)
Wrap Color: Pastel green
Ring Color: Grey
Datasheet Links:
http://7087715.s21d-7.faiusrd.com/0/ABUI...1468803478
Manufacturer
http://www.firstbattery.com/product/
Pictures:
#29
Hey Mike here are a couple of pics of one of my LGDBB331865(J253I102A1) cells.
No data on these at the moment. I have other cells that need to be uploaded later.
Just found some specs on these
http://lygte-info.dk/review/batteries201...%20UK.html
capacity testing with cups of tea, an Imax B6-AC v2 that i've had for a while & a new Opus BT-3100 v2.2 Big Grin Cool
#30
CGR18650DA
