  • 1 Vote(s) - 5 Average
Processed Submissions and Updates
#41
good unknown cell all over 2000mah most 2200-2350mah
Google search turned up nothing on markings
 markings on cell
+ICR18650A-2000mah-
 3.7V   FS  15K11
Note: Can you please take some pictures that are more in-focus? Thanks.
#42
Samsung ICR18650-22 (no letter)
Data: http://www.houseofbatteries.com/document...650-22.pdf
Came from an HP 8-cell 14.8V battery (forgot the model number), tested at around 2000mAH for the cells that worked, 3 were 0V/internal short.
Note: Added, thank you!
mike likes this post
#43
Samsung ICR18650-22B photos
No other info..
LGES318650 photos
Undocumented 18650 cell:
LGEP218650
purple wrapper, white ring
photos for Samsung ICR18650-22FU
Green wrapper
White ring
#44
Sona battery pack  LS LR1865LA cells from alarmhookup (ebay)
What I found on the net they are Tianjin Lishen 18650 electric tools lithium LR1865LA10C  cells
white/light grey ring Green wrapper Gold band on negative end.
The cells are green the gold band on the one i took the photo of is mylar . Just opened another pack up and no mylar all a pretty green.
new photos hopefully better
the batteries kept rolling  so I placed a piece of board in front of them for the photos
later floyd
better pics at last
 The last pack I processed hada few cells with a letter- six digit number  C,D, F are the letters I have seen so far.
#45
Some pics of the recently acquired PK Cells. Capacity appears to be real.
#46
Brand:
Sanyo
Model:
UR18650H
Capacity:
1900mAh Rated
Voltage:
3.70V Nominal
Charging:
4.20V Maximum
1900mA Standard
Discharging:
2.5V Cutoff
Description:
Red Cell Wrapper
Black Insulator Ring
18650 Form Factor
Data References:
http://www.houseofbatteries.com/documents/UR18650H.pdf
Photos:
#47
Here's a new cell
I wasn't able to find a lot of info but apparently, the manufacturer name is "Sairi" or "Shenzhen Sairi Battery Co.,ltd" and there's some info on these pages:
https://www.alibaba.com/product-detail/-...a830BIjQul
https://www.alibaba.com/product-detail/2...0ebc1US0wB
#48
Lishen LS LR1865LA li-ion 2000mAh 10C 20A
Технические характеристики:
Номинальная мощность: 2000mAh
Модель: LS LR1865LA
Номинальное напряжение: 3.6V / 4.2V
Зарядное напряжение: 4,2 ± 0,05 В
Разрядное напряжение: 2,75 ± 0,05 В
Стандартный ток зарядки: 1C
Стандартный ток разряда: 1C
Максимальный ток заряда 1С (T≥10 С)
Максимальный ток разряда: 10C 20A (t≥0 С)
Сопротивление: ≤ 15 мОм
Рекомендуемая температура: при зарядке 0 ~ 45 С, при разрядке: -20 ~ 60 С
Размер: 65,1 х 18,4 мм
Вес: 46 г
haven't found datasheet yet. but it is out there.
 later floyd
Note: Need pictures before we can create a database entry...
#49
Lishen (LS) LR1865SE
Gray White (same as 1865SF)
Lithium ion (Cylindrical)
Nominal Capacity: 2200mAh
only info I could find: https://fccid.io/UL/TIANJIN-LISHEN-BATTE...T-STOCK-CO
LG AAS31865
Is already in the DB but mine appear to have a lighter shade of blue wrapper.
Note: Added as a variant to existing entry, thanks!
LG EP21865
Purple White
Nominal Capacity: 2600mAh
only info I could find: https://www.tokopedia.com/kisahkomputerk...650-lg-ep2
Note: Added pics and capacity to existing entry.
Sanyo/Panasonic UR18650A
Is already in the DB but mine have a purple ring, perhaps like the one noted in the DB without a model number?
Markings SANYO L
UR18650A N35A
Datasheet as attachment
.pdf   SANYO UR18650A.pdf (Size: 177.9 KB / Downloads: 112)
#50
Panasonic
UR18650NSX
Let me know if these photos are not ok Mike
LGDBHE41865
                                                Choose LiFe  Wink
                      May all your batteries be fully charged and perfectly balanced  Cool
