  • 1 Vote(s) - 5 Average
Processed Submissions and Updates
Does anyone have any photos of the Samsung INR18650-35e cells?
https://www.orbtronic.com/content/samsun...50-35e.pdf
Note: We need pictures to create a database entry Wink
I have these same cells in dark purple.
Note: Added as a variant, thank you!
I have these cells too, but from a different factory LGGBF1L1865
Note: Added, thank you!
LGDBMH11865
Model
LG MH1
Nominal capacity
3200mAh
Nominal voltage
3.7V
Charge voltage
4.2V
Discharge cut-off voltage
2.75V
Charger method
CC-CV
Weight
45±1.5g
Charging time
Standard charge: 2.5hours
Rated charge:2.0hours
Temperature:
Charge: 0 to 40°C
Discharge: -20 to 60°C
storage: 1 year:-20 to 25°C
3 months:-20 to 45°C
1 month:-20 to 60°C
Adding info below, because the board requires me to make at least one post before adding links...
Seen some discussion on these Panasonic cells, but none in this thread or in the database... So here goes!
Data Sheet (PDF)
Note: Already got it, thanks!
GP Batteries GP1865L180
Nominal Voltage: 3.7 V
Capacity: Typical: 1800 mAh
              Minimum: 1750 mAh
Discharge: Standard: 360 mA
                Max: 1800 mA
                Cutoff 2.8 V
Charge:  1080 mA
              4.2 V
.pdf   1865L180.pdf (Size: 115.22 KB / Downloads: 130)
Note: Created database entry. If you have time, please upload a few pictures in a standard aspect ratio (non-cropped) that we can use. Thanks!
n6uum likes this post
Sanyo UR18650A R2112
WHITE plastic
Note: We already have these in the cell database, but thanks!
hbpowerwall likes this post
Here's some pictures of the purple variant, which has part number LGEBE11865:
(10-11-2019, 07:11 AM)richie241 Wrote: Sure Wink
Datasheet: http://www.nkon.nl/sk/k/m36.pdf
Test Info: https://lygte-info.dk/review/batteries20...%20UK.html
Note: Added, thanks!
Sanyo UR1665ZTA
Typical Capacity: 2500 mAh, Nominal Capacity: 2380 mAh
Charging Voltage: 4.35 V
Charging Current: 1190 mA
Cutoff Voltage: 2.5 V
Data Sheet
.pdf   Sanyo-UR16650ZTA.pdf (Size: 126.7 KB / Downloads: 59)
Update: GP Batteries GP1865L180 New Pictures
Note: Updated, thank you!
