Sanyo UR18650A Cell Specifications
Brand:Sanyo
Model:UR18650A
Capacity:2100mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1510mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
420mA Standard
--- mA Maximum
Description:Red Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
https://na.industrial.panasonic.com/site...asheet.pdf
Pictures:
Recently tested a few of this (with white ring) and the capacity was above 2200mAh in many cases (used the LiiToKala lii-500)
I Think this is the correct datasheet for this cell. http://www.meircell.co.il/files/Sanyo%20UR18650A.pdf and https://www.scribd.com/document/32950069...ifications
Nominal Capacity is 2150mAh
Typical Capacity is 2250mAh
Discharge Max(A) is 4.30Amps
I have been finding more and more of these cells lately, with purple ring allright, but with no "UR18650**" text whatsoever. There only is "SANYO R1112 N41B" on the sample I have on hand right now. The lenovo pack it came out from claims 11.1V and 48Wh nominal, which calculates to 2162mAh nominal for the cells.
(01-10-2019, 05:23 PM)Mago_Kabal Wrote: Recently tested a few of this (with white ring) and the capacity was above 2200mAh in many cases (used the LiiToKala lii-500)
Yep I have the same results with the LiitoKala  it reads at least 5% high.
If the IR of the cell is ≤55mΩ you will get good results
Last count as of 8/7/2019
For Info Google Drive
Wrong picture in the frame on this one.
(10-08-2019, 09:24 AM)WuggyBuggy Wrote: Wrong picture in the frame on this one.
Both the purple and white cells pictured above are UR1865A. We don't have any full-size pictures of the white-ringed cell though. If you have some of the cells, please consider taking pictures and submitting them here Smile
