Sanyo UR18650A Cell Specifications
Brand:Sanyo
Model:UR18650A
Capacity:2100mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1510mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
420mA Standard
--- mA Maximum
Description:Red Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
https://na.industrial.panasonic.com/site...asheet.pdf
Pictures:
Recently tested a few of this (with white ring) and the capacity was above 2200mAh in many cases (used the LiiToKala lii-500)
I Think this is the correct datasheet for this cell. http://www.meircell.co.il/files/Sanyo%20UR18650A.pdf and https://www.scribd.com/document/32950069...ifications
Nominal Capacity is 2150mAh
Typical Capacity is 2250mAh
Discharge Max(A) is 4.30Amps
I have been finding more and more of these cells lately, with purple ring allright, but with no "UR18650**" text whatsoever. There only is "SANYO R1112 N41B" on the sample I have on hand right now. The lenovo pack it came out from claims 11.1V and 48Wh nominal, which calculates to 2162mAh nominal for the cells.
(01-10-2019, 05:23 PM)Mago_Kabal Wrote: Recently tested a few of this (with white ring) and the capacity was above 2200mAh in many cases (used the LiiToKala lii-500)
Yep I have the same results with the LiitoKala  it reads at least 5% high.
If the IR of the cell is ≤55mΩ you will get good results
Last count as of 8/7/2019
For Info Google Drive
Not your average Wolf
            Cool
Wrong picture in the frame on this one.
(10-08-2019, 09:24 AM)WuggyBuggy Wrote: Wrong picture in the frame on this one.
Both the purple and white cells pictured above are UR1865A. We don't have any full-size pictures of the white-ringed cell though. If you have some of the cells, please consider taking pictures and submitting them here Smile
100 User(s) read this thread:
hbpowerwall (02-05-2019, 04:40 AM), mike (10-08-2019, 11:37 AM), askmike72 (01-31-2019, 10:37 AM), riveracc1 (09-30-2019, 03:46 PM), JapanPowerWall (07-08-2019, 02:47 AM), ruby2 (09-05-2019, 03:33 AM), Korishan (09-22-2019, 10:37 PM), PAF (10-08-2019, 02:28 PM), jdeadman (10-08-2019, 12:24 PM), 2146 (09-19-2019, 03:18 PM), The-J-Man (04-02-2019, 06:24 PM), watts-on (02-04-2019, 11:40 AM), João Luis Martins (01-20-2019, 09:07 PM), Mark Lex (02-25-2019, 08:42 AM), Stefaan De Ridder (12-06-2018, 07:34 AM), Geek (10-14-2019, 12:08 AM), floydR (01-04-2019, 07:34 PM), mickduc (01-29-2019, 11:14 PM), SemaJG (03-08-2019, 01:11 PM), dythewitt (05-27-2019, 09:20 PM), ChrisD5710 (09-28-2019, 07:47 AM), Oz18650 (08-11-2019, 02:25 AM), rev0 (09-19-2019, 09:38 PM), JamesBourgeois (10-02-2019, 11:24 PM), kody (09-11-2019, 08:50 PM), Jensk (09-15-2019, 03:05 PM), modido (09-27-2019, 07:12 PM), djuro (06-30-2019, 10:53 AM), uploader18 (03-31-2019, 12:25 PM), kosmo (02-19-2019, 06:27 AM), cat23 (09-27-2019, 06:19 AM), Drokz (08-22-2019, 09:05 PM), Chablis_m (03-10-2019, 10:10 PM), mbrunton (04-11-2019, 11:58 AM), thanar (09-22-2019, 08:18 PM), Amigaman (12-07-2018, 03:47 PM), Ibiza (09-23-2019, 11:21 AM), Zvonko000 (02-15-2019, 03:31 PM), thunderheart (01-07-2019, 01:28 AM), JamesVa (03-07-2019, 03:01 AM), özkan (12-15-2018, 08:43 AM), hamzacanalt (01-02-2019, 07:11 PM), Ivan Conicov (03-02-2019, 05:06 PM), Cecere (06-27-2019, 06:16 AM), avm131 (07-14-2019, 12:07 AM), npagonor (01-21-2019, 06:10 PM), MikeJF (02-14-2019, 04:45 AM), Walde (01-20-2019, 02:04 PM), Riplash (02-04-2019, 01:04 AM), Heike73 (01-16-2019, 06:03 AM), 100fuegos (02-08-2019, 09:18 PM), bukvaahmed@gmail.com (02-17-2019, 03:05 PM), Katarn_89 (04-29-2019, 11:22 PM), djotter (07-23-2019, 08:41 AM), Duswillum (06-12-2019, 09:23 AM), barias (08-23-2019, 02:31 PM), deanpeart (10-16-2019, 02:45 PM), Vojislav Mazinjanin (02-13-2019, 12:48 PM), unclebob (02-04-2019, 03:07 PM), Sammm (02-03-2019, 10:18 PM), schmue (05-18-2019, 07:32 AM), Yungo (12-19-2018, 09:07 PM), Dragora (03-23-2019, 08:45 PM), chuckp (02-03-2019, 08:48 PM), Mago_Kabal (01-31-2019, 04:14 AM), guisopr98 (01-08-2019, 08:05 PM), WuggyBuggy (10-10-2019, 02:41 PM), emuland-metroman (09-23-2019, 05:13 PM), FiXiLiX (12-24-2018, 11:42 AM), Chass90 (07-12-2019, 08:48 PM), Beholder (01-10-2019, 11:12 PM), 2pPac (09-16-2019, 10:27 AM), KBoffGrid (03-26-2019, 10:14 AM), clupton (06-25-2019, 10:41 PM), PacMar (12-15-2018, 11:37 AM), titosairbagsvc (01-08-2019, 02:03 AM), RevampKC (02-01-2019, 08:22 PM), kremvax (06-28-2019, 06:51 PM), Thamer300 (12-08-2018, 04:46 PM), cowpen (04-11-2019, 09:59 PM), Triple L (09-01-2019, 12:59 AM), captainjacksparrow (01-22-2019, 01:33 PM), castlestone (12-19-2018, 01:42 PM), Wolf (10-08-2019, 01:14 PM), Bastler_Ro (02-03-2019, 09:34 PM), weebe (03-27-2019, 05:00 AM), Pelle (02-24-2019, 04:05 PM), brannen1 (03-10-2019, 04:35 AM), Scottietheyoung (12-28-2018, 02:10 AM), Matt (12-30-2018, 09:57 PM), Generic (10-04-2019, 03:57 AM), rettore (12-27-2018, 07:58 PM), KrusherPT (12-07-2018, 08:58 PM), jhunmojica (04-24-2019, 07:57 PM), DIVPowerwall (10-06-2019, 11:02 AM), stevelectric (03-18-2019, 01:11 PM), Tranminhthu (12-22-2018, 04:24 PM), PaulDane (04-12-2019, 01:57 PM), Stonewall (01-14-2019, 07:20 AM), ajw22 (10-08-2019, 09:57 AM)
