LG LGDBB11865 Cell Specifications
Brand:LG
Model:LGDBB11865 (ICR18650B1)
Capacity:2600mAh Rated
Voltage:3.75V Nominal
Charging:4.35V Maximum
1275mA Standard
5100mA Maximum
Discharging:3.00V Cutoff
510mA Standard
2250mA Maximum
Description:Turquoise Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://d112tss1dzpest.cloudfront.net/wp-...pdf?323d81
Pictures:
Hi, the Charge/discharge max current is swapped. It charges at max 2250mA and discharges at 5.1A
