12-06-2018, 07:42 PM
Data References:
http://www.molicel.com/ca/pdf/IMR18650E.pdf
Pictures:
Brand: | Moli Energy |
Model: | IMR-18650E |
Capacity: | 1400mAh Rated |
Voltage: | 3.80V Nominal |
Charging: | 4.20V Maximum --- mA Standard 6500mA Maximum |
Discharging: | 2.50V Cutoff --- mA Standard 20000mA Maximum |
Description: | Grey Cell Wrapper Black Insulator Ring 18650 Form Factor |
Data References:
Pictures:
Nissan Leaf Battery!! Contains 48 Leaf Modules, 24kWh Capacity, Freight Shipping
