Panasonic NCR18650BD Cell Specifications
Brand:Panasonic
Model:NCR18650BD
Capacity:3000mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
900mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
610mA Standard
10000mA Maximum
Description:Grey Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
https://voltaplex.com/media/whitepapers/..._Sheet.pdf
https://na.industrial.panasonic.com/site...asheet.pdf
Pictures:
You got the color of this cell written correctly but the image is innacurate. I didnt even see it on the list until i searched it by name.
The c ed ll wrapprr is gray, but the image looks brown and the color square thing on the cell database list looks brown.
rgb(163, 163, 163);
#a3a3a3
#999999
Go by the rgb code, not the picture.
The pic is lighter than the true color
