I've started building a new power wall 14s20p as proof of concept and then plan is toexpand it to 14s40p/14s60p.
PV array contains 22 Canadian Solar 285W, Sunny Boy 5000 on grid inverter, ~5 kw installed power.
My plan is to use Sofar ME3000SP, so nothing will be changed on existing grid, just plugin new inverter, clamps and battery.
All cells will be packed20p (4x5) with 2A glass fuse on each cell,bus will be coper 6mm. I don't plan using packets bigger than 20p as I can upgrade when I get a batch of 280 testedcells.
Bus between strings will be from aluminium 2x30mm.
Fuseof 60Amps to the inverter.
Cells are only from laptops, over 35 different models, planning to keep only cells with capacity over 1900.
Until now over 300cells, nominal capacity average 2338, tested capacity average 2174, ~20 tested.
My inspiration was from this link:a2delectronics.ca/2018/06/22/2-4kwh_diy_powerwall/
Does anyone used ME3000SP until now with with home made battery?
