Samsung 40T - 35A 21700 Li-ion battery's capacity test
Video
Hi guys! I've tested the Samsung INR21700-40T (35A) at up to 20A discharge (limited by my equipment).
[Image: 221767_original.jpg]
The battery was bought from my reliable supplier (Queen Battery) and tested with ZKETECH EBC-A20 and a self-made battery holder. It's a PC-connected battery tester supporting 4-wire measuring and discharging at up to 20A.
[Image: 87638_original.jpg]
[Image: 210421_original.jpg]
[Image: 209931_original.jpg]
I've followed all the prescriptions of the IEC61960-2003 standard concerning battery's capacity measurement. Before each discharging cycle each battery was charged at standard charge current mentioned in its datasheet to charge end voltage. Before each discharging or charging i've held a 1-1.5hrs pause. The environment temperature was 23.5-24.5°C. To be sure in results i've done each test minimum twice (usually 3-4 times).
The cell is marked as INR21700-40T SAMSUNG SDI 2I15 which means that the production date is 05 Jan 2018.
[Image: 221029_original.jpg]
The main specs from Samsung 40T datasheet:
Capacity: 4000mAh
Nominal voltage: 3.6V
Standard charge current: 2A (200mA cut-off)
Fast charge current: 6A (100mA cut-off)
Charge end voltage: 4.2V
Max. continuous discharge current: 35A or 45A with 80°C temperature cut
Discharge cut-off: 2.5V
AC impedance at 1KHz: 12mΩ
Max weight: 70g
Measured DC IR at 4A in fully charged condition was 12±0.5mΩ
Measured weight of the tested cell was 66.57g
[Image: 221353_original.jpg]
Test results:
[Image: 220887_original.png]
At 0.2C (0.8A) capacity is almost 4100mAh and it doesn't go below 3800mAh even at 20A discharge! Curves look beautiful, without abnormal sags.
This cell is the evolution of 30T which i've tested before and it brings the capacity of high drain 21700 cell to a new level. It also supports 45A discharge but at discharge rates above 35A the temperature must be properly controlled.
Here is the video version of this review
[Image: 221513_original.jpg]
I've recently launched my blog where you can find all my reviews in one place. Every new test/review will be first published on YouTube and in the blog. I'll be happy to see new subscribers, comments, suggestions and just your thoughts.
jdeadman, mike, Korishan And 2 others like this post
You have another sub Smile
thunderheart likes this post
Thanks Wink
Nice.
Have you thought of making your own very high constant current load?
I'm currently in the process of making one, although I have to find a way for traces not to blow up Smile
Hi!
I'm thinking on adding temperature curves and upgrading my battery holder.
(12-19-2018, 07:39 PM)thunderheart Wrote: Hi!
That would definitely be a nice touch.
Yeah, that would be dope.
One other thing he could do is parallel electronic loads.
However, the connector resistances basically need to be the same at all times.
