01-25-2019, 05:58 AM
Hey all.
01-25-2019, 01:14 PM
(This post was last modified: 02-08-2019, 04:28 PM by bournevexed. Edited 1 time in total.
Edit Reason: keeping it clean
Thanks for the reply & good idea on charging LEDSchlucker! I think I'll get another Opus!
01-25-2019, 02:23 PM
(This post was last modified: 02-08-2019, 04:29 PM by bournevexed. Edited 2 times in total.
![]() ![]() I see my mistake I meant @2A discharge not @1A. Apologies!! ![]()
01-25-2019, 06:11 PM
If you buy another Opus, I heard something about an Opus BT-C3400 which has bigger slots. If it has the same firmware it would also have the same capacity ratings.
This for example: https://www.amazon.com/Universal-Battery...B076P52TMH But it can also just 1A at four slots at the same time.
01-25-2019, 07:06 PM
(01-22-2019, 01:10 PM)bournevexed Wrote: Will take a while with 7 at a time on 4 chargers(2 liitokalas, 1 opus bt3100 & 1 imaxb6v2) but I'll get there lol Erm, not exactly bournevexed. I have six Opus's, four still working 100%, and I love them to bits. BUT they aren't used as chargers... welcome to the forum! IMHO, The Opus BT3100 is NOT suitable as a charger -- ESPECIALLY for old/recycled cells. You may wish to thrash your new cells in them but I wouldn't recommend that either. I have TWO basic reasons for this assertion: 1/ Basically the method of charging it uses is very brutal pulses which can be way out of spec for the cells. To quote from the battery charger testing master (!), talking about v2.1 ... "The first version of this charger had some nasty 9A current spikes from the power supply, this made the charger show wrong mAh values when charging. In this version the spikes are reduced to 6A and the charge current is stable, this means the charger can measure correctly." https://lygte-info.dk/review/Review%20Ch...%20UK.html 2/ In any case, if you are like me, the capacity TESTING is the bottleneck. So I use 'big 4s20p trays on a CC/CV buck converter to 'slow cook' my precharging batts (anything <3v) to get them up to 3.8V ish then top them off with an iSDT balance charger. Takes 5-10 days. but then I have 160 cells to test (I generally process my cells in pairs). And for day to day use I use 6s4p yoke's on balance chargers to keep things charging for the Opus capacity testers. I mention this all now, as you are ready to blast away at your task, and thought it prudent to tweak your method so you dont end up changing the way you grade / measure cells half way through your mission. Hope That Helps. PS you may want to pop open your Opus and future ones if you get more to check that J1 is set the same on all of them, as this setting fundamentally changes the capacity values it gives.
01-26-2019, 03:28 PM
(This post was last modified: 01-29-2019, 04:30 PM by bournevexed. Edited 2 times in total.)
Thanks DCKiwi, yeah I have the Opus V2.2. Yeah!! I was aware of the hidden switch I came across one of averagejoe's videos about it before the thing arrived!
so I was quite lucky there & did check it when it arrived! Though I am not actually ready to blast away at my task. I've had my used cells sat in 4 boxes for a good while now. I charged all up I will give them another week! Then I'll start to capacity test them. most of my cells were paired but i thought i should split them so I did! Thanks for the link very good info on that I have come across it a few times! I tested the 4th & final box last night for voltage to pull only 8 cells that were below 4.15v As I'm not using any that drop below 4.15v. I want a good marker/leeway for my 24v system at 28v max the cells would be at 4.0v each. majority of my cells are still at 4.19/18v with the a small amount at 4.16/17v. My highest cell a Panasonic CGR flickers between 4.21/20v still after 3 weeks!! ![]() ![]() ![]() ![]() I have a picture of it in my head lol.
01-26-2019, 08:15 PM
(This post was last modified: 02-06-2019, 10:06 PM by DCkiwi. Edited 1 time in total.
Edit Reason: added link to J1 discussion thread
(01-26-2019, 03:28 PM)bournevexed Wrote: Thanks DCKiwi, yeah I have the Opus V2.2. Yeah!! I was aware of the hidden switch I came across one of averagejoe's videos about it before the thing arrived! Thats all good, but not at all what I meant. (a switch is not a jumper, AND that switch is always shipped set correctly/4.20V). I referred to J1 -- this is a jumper on the PCB, by way of solder bridge. It matters less which way it is set, than all your Opus's being set the same. Just like it doesnt matter if your tape measure is wrong, so long as its the only one you use for all measurements ... if you get my drift. refer this thread which has images too (01-26-2019, 03:28 PM)bournevexed Wrote: most of my cells were paired but i thought i should split them so I did! why did you split them? I process all my cells in pairs ... dont have time or inclination to double my workload without adequate reason. (01-26-2019, 03:28 PM)bournevexed Wrote: I tested the 4th & final box last night for voltage to pull only 8 cells that were below 4.15v As I'm not using any that drop below 4.15v. I want a good marker/leeway for my 24v system at 28v max the cells would be at 4.0v each. majority of my cells are still at 4.19/18v with the a small amount at 4.16/17v. My highest cell a Panasonic CGR flickers between 4.21/20v still after 3 weeks!! wow, thats really harsh! I too like cells that dont drop down, but many when they are so hot (charged to limit) lose V ok. I generally go by the rough rule of >4.12V after a weeks storage. BU has a nice graph to illustrate self-discharge: https://batteryuniversity.com/learn/arti..._discharge but yeah, I do love it when after a couple of weeks checking for selfdischarge the cell measures 4.20V ... makes me smile for sure. are we sick people? lol ....
01-27-2019, 01:15 PM
(This post was last modified: 02-05-2019, 04:06 PM by bournevexed. Edited 2 times in total.)
YEAH we are sick!!
![]() ![]() & a few paired cells I liberated weren't spot welded together very well & came apart quite easy!
02-08-2019, 04:41 PM
hey all,
just letting you all know my (140) 26650 liitokala cells & the malectrics spot welder have arrived in the UK!! I started capacity testing my sourced 18650s. I'll share the results when I'm done & also upload a few shot of the new 26650 cells. Hope this post is in the right place if not sincere apologies. ![]() ![]()
02-15-2019, 05:47 PM
My parcel arrived!! Full of Liitokala 26650 5000mAh cells
![]() ![]() ![]() Anyway here are some pics & a video i did lol ![]() ![]() ![]() https://youtu.be/Y7Uiwbcngdc |
« Next Oldest | Next Newest »
