MI powerwall
When you say coolers are you recommending an additional fan or are you suggesting something I haven't seen yet?
(02-06-2019, 06:54 PM)Kevin Mason Wrote: When you say coolers are you recommending an additional fan or are you suggesting something I haven't seen yet?
Don't know if you are asking Overmind or just in general.
There are several "mods" out there to add additional cooling to the OPUS.
The best one I have seen so far is this https://secondlifestorage.com/t-Download...n-Mod-Base
I do have to get me a 3D printer soon. Smile
But there have been several other implementations on that theme.
https://secondlifestorage.com/image/dendhc
Last count as of 8/7/2019
For Info Google Drive
Thanks Wolf I have not seen these. I have experienced the chargers displaying all zeros on numerous occasions which I attributed to overheating. I will look into these. I like your work station, very neat and organized. I too don't watch much tv. Mostly YouTube videos anymore.
(02-06-2019, 07:41 PM)Kevin Mason Wrote: Thanks Wolf I have not seen these. I have experienced the chargers displaying all zeros on numerous occasions which I attributed to overheating. I will look into these. I like your work station, very neat and organized. I too don't watch much tv. Mostly YouTube videos anymore.
Yes if you are getting all zeros than the overheat cut off has kicked in.
I did notice that also, so I have relinquished to discharging at .5A takes a bit longer though. Once I get myself a 3D printer I will build the mod for the OPUS and maybe design the same for the LiitoKala and Foxnovos. Right now though the timing at .5A is just fine as I stock all the charger/testers with cells in the AM before I go to work and when I get home they are mostly done. If anything they are usually back in the recharge cycle and I just record their mAh results pop them out and put them into my dedicated chargers. Then I load them up again and do the same thing in the AM that way I can test ~80 cells in 24hrs.
"Neat and organized" Thanks Smile
Well when you are processing as many cells as possible and recording them all in a spreadsheet you kinda got to know where stuff is Big Grin .
By the way speaking of spreadsheets I got into this harvesting like a bull into a china shop and just started ripping packs apart popping cells into the chargers and recording just the mAh on the cells. I don't need no stinking record of each cell I said. Big mistake. I now record every cell that may have some life in it. The only ones I dont record are the CID trips and the really high IR ones although I probably should just to get the percentages documented.
Anyway happy cell harvesting!
Hey Kevin. Are you in Michigan?
(02-26-2019, 03:53 PM)mishok Wrote: Hey Kevin. Are you in Michigan?
Yes in the Holly area.
I made a new charging/testing station. I used a 5 volt 30 amp power supply and a computer power supply. I use the top row for initial charging and the second row to charge the tested cells back up. I mounted fans behind each Opus charger/tester and it has eliminated overheating. The single cell holder is hardwired into the multimeter and I still have the leads connected for other uses. I crimped the electrodes on the cell holder to make cell testing easier to insert and extract. I am still waiting on the final Opus charger to finish the installation. The one I received was defective so I sent it back and ordered another. I'm up to 20 kwh in tested batteries and still going. I hope to start construction on the power shed soon.
Neat charging station idea. Love the cooling solution for the Opus
(05-16-2019, 11:52 PM)Geek Wrote: Neat charging station idea. Love the cooling solution for the Opus
Thanks for the encouraging comments. The only problem is it is a hungry beast and hard to keep it fed.
Geek likes this post
100 User(s) read this thread:
hbpowerwall (02-07-2019, 05:18 AM), AZ_Tekkie (07-11-2019, 05:15 AM), daromer (05-12-2019, 09:53 PM), Sean (05-12-2019, 08:14 PM), mike (02-02-2019, 02:10 AM), riveracc1 (05-31-2019, 03:36 AM), Korishan (05-17-2019, 01:14 AM), PAF (05-17-2019, 08:18 AM), Franky Beuselinck (05-17-2019, 07:59 AM), jdeadman (05-13-2019, 07:00 PM), wim (05-17-2019, 05:41 AM), wimpie007 (02-12-2019, 06:23 PM), melsom (04-13-2019, 11:04 PM), The-J-Man (02-04-2019, 03:17 PM), civitou (02-03-2019, 04:36 PM), watts-on (05-17-2019, 10:55 AM), Dan Lim (03-02-2019, 10:23 PM), jesusangel (05-12-2019, 08:09 PM), Hanssing (03-01-2019, 12:26 PM), Stefaan De Ridder (05-13-2019, 01:40 PM), KaminoReal (05-25-2019, 07:04 PM), Shade (03-01-2019, 02:54 AM), Geek (05-17-2019, 05:52 AM), mr_hypno (02-07-2019, 03:52 PM), floydR (02-03-2019, 01:59 AM), AlexCPU (02-07-2019, 10:29 AM), David Arnshelm (02-26-2019, 07:59 PM), Grumplestiltskin (05-15-2019, 07:22 AM), zag2me (02-28-2019, 03:15 PM), Oz18650 (05-17-2019, 11:57 AM), karmi27 (02-27-2019, 10:52 AM), bigblue (02-03-2019, 08:03 AM), Ste Collister (02-06-2019, 08:28 PM), Charly144 (06-09-2019, 06:29 AM), djuro (02-27-2019, 01:29 PM), ClardiPower (02-04-2019, 01:44 PM), Jason Morris (02-01-2019, 03:53 AM), Drokz (03-21-2019, 08:19 PM), Chablis_m (05-17-2019, 02:16 AM), thanar (05-13-2019, 06:38 AM), Redpacket (05-13-2019, 12:35 PM), completelycharged (02-02-2019, 09:53 PM), Ibiza (05-17-2019, 05:59 PM), Onizuka (02-26-2019, 04:48 PM), Jonas Vanbeveren (05-23-2019, 12:17 PM), Oliman (05-17-2019, 12:55 AM), cadric (09-02-2019, 11:22 AM), choncy12 (05-20-2019, 02:04 PM), Sholphin02 (06-06-2019, 12:27 AM), Walde (02-06-2019, 04:31 PM), Riplash (02-07-2019, 12:52 AM), 100fuegos (05-18-2019, 06:17 PM), mishok (02-26-2019, 03:53 PM), bukvaahmed@gmail.com (03-06-2019, 07:47 PM), Katarn_89 (05-13-2019, 01:55 AM), w0067814 (02-27-2019, 09:59 PM), michaell (05-17-2019, 07:27 PM), neowolf (05-31-2019, 08:26 AM), chuckp (05-18-2019, 12:04 PM), Kevin Mason (05-17-2019, 02:03 AM), photon4 (02-08-2019, 12:59 AM), keaton85 (01-31-2019, 06:09 AM), WuggyBuggy (05-17-2019, 09:09 AM), emuland-metroman (05-17-2019, 11:40 AM), Beholder (02-28-2019, 10:34 PM), Leipi35 (01-31-2019, 08:47 PM), runsnbunsn (02-11-2019, 06:47 PM), cowpen (01-31-2019, 06:33 PM), singlecell (03-15-2019, 02:00 AM), Dirty Optics (02-03-2019, 04:15 AM), Shawndoe (05-14-2019, 05:07 AM), Wolf (05-17-2019, 02:44 PM), Lekr (05-21-2019, 06:53 PM), Scottietheyoung (05-29-2019, 09:16 AM), Wardy (02-10-2019, 02:16 PM), camthecam (05-18-2019, 09:43 PM), Generic (03-01-2019, 12:04 AM), rettore (02-28-2019, 11:40 AM), xenomorph113 (02-03-2019, 12:22 AM), Solardad (02-03-2019, 02:27 AM), Speicher (03-03-2019, 06:10 AM), stevelectric (02-07-2019, 05:03 PM), richie241 (05-14-2019, 12:18 PM), eric.peton@laposte.net (03-05-2019, 09:15 PM), ajw22 (02-28-2019, 11:23 PM), BmoreThor (05-18-2019, 06:41 PM), RikH (05-21-2019, 03:51 AM), lloulou11 (03-04-2019, 10:58 PM), newone972 (02-07-2019, 02:36 PM), DomingoRP (02-26-2019, 07:59 PM), oloyeadeniran (05-15-2019, 11:29 PM), airvan (03-07-2019, 09:12 AM), mart1nn (05-18-2019, 03:37 PM), OffGridInTheCity (05-13-2019, 03:53 PM), Maniac_Powerwall (03-05-2019, 09:19 PM), LEDSchlucker (03-02-2019, 09:39 PM), zoookii (03-02-2019, 12:55 PM), apple921509 (02-13-2019, 02:24 AM), Rhoos (08-27-2019, 04:09 PM), tsmurray (03-08-2019, 11:12 PM)
